Fg Offsets And Tyre Questions
Dillz
  • Member For: 16y 2m 17d
you thinking of keeping the darkies and just getting rear spacers?
Yea it's the only way I will get the rite offset and no one knows the rite offset for a fg . everyone is just guessing
  • A much better forum
  • Member For: 16y 5m 27d
People know the right offset but I changes with wheel width... And you haven't said whether you will have rolled guards? Pumped etc?
  • Member For: 17y 7m 24d
Exactly there is no such thing as the perfect offset. Use other peoples ones as a guide and just have a crack.
  • Member For: 13y 1m
I will b using 20x8.5 with 35 offset fronts with 20x10 with 40 offset rears will use spacers at front to match linement with rears if needed wheels should arrive next week and hopefully have all done next week with it lowered as well I will put pics up straight away
Tyres make a huge difference as well... 275's can come 3 cm different in width...
Whinging about people not knowing stuff is just bullsh*t...
Each car is different too... Depends on how diff is centered... Can be out...
Setup is exactly like mine except I don't run spacers on the front. Don't need them plus they are dangerous and illegal.
The whole point of staggered is you want the back to look wider then the front.
  • Pitlane Member
  • Member For: 17y 8m 18d
I reckon 5mm is ok, I wouldn't go any more though.
I would have 5mm on the front now except I would need to wind my coilovers up!
Edited by TRA1NR
They are definitely illegal, poor quality ones will move around too. Plus throwing your front track off will probably screw up all your steering and cornering.
I can't even tell on mine.
Do it right and get the offset to push the wheels out if you must.
