  • New Member
  • Member For: 5y 3m 23d
I'm yet to jack it up and have a look.. I've been using the willtheyfit calculator online. Which has the same measurements you got.
I was after confirmation someone has fitted some 18inch,  by 9 wheels
  • XR50T
  • Member For: 11y 11m 24d
It's an FG offsets thread ya numpty.
  On 02/01/2020 at 9:34 AM, poolkeeper said:
 Will a 18 x 9 +38 work on the front?
Expand
Nope
It'll likely foul on the upright.
I have 18x10 +12 and the 18x9 +38 sits way further in.
  • Dropping a turd
  • Member For: 17y 5m 29d
Best offset for the front of FG is +20 or +25. Fg has a larger guard,.
  • New Member
Nope
Expand
Sweet thanks mate, the same wheels I mentioned also come in a +30 offset. You reckon this offset will provide enough clearance
  • XR50T
Should be fine.
Check it with what tyre size you want to be safe. It is only 6.7mm further in that factory so shouldn't be an issue.
  • 5 weeks later...
  • 2 months later...
  • New Member
  • Member For: 5y 2d
Hi everyone, I've tried doing my research but thought I'd ask for assistance. I'm getting these wheels and was wondering if 20x9" 20 would fit on the front and 20x10.5 40 would fit on the rear? I'm going to bag it eventually so just need clearance. Thanks
  • Dropping a turd
Front will be ok. Rear will need to be +30 or +35.
Will to check clearance if you have brembo
Edited by arronm
