OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 8m 27d Gender: Male Location: Western Sydney Posted 13/03/19 11:36 AM Share Posted 13/03/19 11:36 AM Use willtheyfit.com throw in the stock v new offsets and measure up to see what suits.It will be safe either way, stock has slot of room for movement in or out. Link to comment Share on other sites More sharing options...
MR_FG_09 Donating Members 97 Member For: 13y 2m 13d Gender: Male Posted 31/03/19 11:03 AM Share Posted 31/03/19 11:03 AM Yeah I’ve seen one guy running 9.5” +15 all around but the rears poked a bit and the fronts looked close as. Sadly Rota only make them in 9.5” :( im thinking the +20 might be what I end up doing and then doing some trial and error with ride heights when I get coiloversOld post I know im running 18x9.5 +18 all round on my fg with 245/40/18 tyres F&Rrear guards rolled & sat fine with sssl rears & ssl fronts, its sitting on coilovers now & no scrubbing 2 Link to comment Share on other sites More sharing options...
jair12 New Member 1 Member For: 5y 8m 29d Posted 30/04/19 07:13 AM Share Posted 30/04/19 07:13 AM I'm currently in the process of finding a good set of rims/tyres to suit a 2010 fg xr6 The car im purchasing is the colour code VP (Viper/Purple) I will be running stock suspension and was looking at 19" rims 8.5 front/9.5 rear width. What is the range of the offset that would suit? Furthemore what would be suitable sized tyres for these rims considering I'm wanting a staggered set-up. I would also like a slighly lower front than rear without suspension mods. Would appreciate some help Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 8m 12d Gender: Male Location: adelaide hills- 'race air' central Posted 01/05/19 07:39 AM Share Posted 01/05/19 07:39 AM (edited) put a level against the guards to the ground (and make sure its plumb). measure the distance from the level to the existing rim. then go to https://www.wheel-size.com/size/ford/falcon/ to find the existing size/ offset of your rims. then go to https://www.willtheyfit.com/ and enter the existing measurements, then the measurements that will make it flush with he guard if you want it flush. adjust for poke, or in a bit, or whatever. I wouldnt go closer to the strut, and if your increasing rim diameter you might even need to go further away. pop your hand to the the top of the rear of the tyre and feel what kind of clearance you have. Edited 01/05/19 07:42 AM by Panda Eyes Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 8m 27d Gender: Male Location: Western Sydney Posted 01/05/19 08:27 AM Share Posted 01/05/19 08:27 AM It's hard to comprehend how many people can't use will they fit.Got a work mate with a ranger and he thinks offsets don't matter.... Link to comment Share on other sites More sharing options...
Jumbuck Member 25 Member For: 5y 11m 20d Gender: Male Location: Melbourne Posted 29/07/19 01:42 PM Share Posted 29/07/19 01:42 PM (edited) advice re: 8.5 inch wheels on FG+ sedans. fitted Work Emotion CR-2P to FG-X sedan. - 19 x 8.5 w’ + 35 offset Wheel fitted with 245 Pirelli P-Zero tyre which sits with 7-8mm clearance of suspension arm, Beware if using the newer P-Zero PZ4 tyre as this tyre has a thick rim protector (10mm+) which causes the tyre to foul on the suspension arm (if using +35 offset - Talking from experience. If anyone making custom order for wheels - and looking for near factory fitment, I would recommend offset of no less than +30 if opting for 8.5 inch wheel. Ensures any 245 tyre used will fit and not foul on suspension arm. +35 will fit, but some high performance tyres with aggressive rim protectors may foul on inner side. Edited 29/07/19 01:44 PM by Jumbuck Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,176 Member For: 16y 9m 18d Gender: Male Location: Melbourne Posted 29/07/19 01:53 PM Share Posted 29/07/19 01:53 PM good solid advice. going to need pics of your setup, though 1 1 Link to comment Share on other sites More sharing options...
MaStars Donating Members 81 Member For: 7y 7m 23d Gender: Male Location: The Gap, Brisbane Posted 06/08/19 06:56 AM Share Posted 06/08/19 06:56 AM Hello there, I am thinking about getting some new rims and run the new 245/35-R19 Falken Fk510 is just got for my factor 19". I like the idea of using OEM style wheels but was looking at the Nissan OEM forged wheels and came across the Skyline V35 Coupe wheels. they are Rays Forged one piece wheels Nissan use from factory. I have found a set relatively cheap on Gumtree for about $650. https://www.gumtree.com.au/s-ad/golden-grove/wheels-tyres-rims/rays-forged-wheels-with-new-tyres/1225066514 Apparently they are quite light about 8-10Kg per wheel, id say much lighter than the current ones, so maybe a bit of a performance gain also. Has anyone on here fitted a set of these on a FG falcon Sedan from my understanding and using the "will they fit" website the sizing and offset difference isn't huge from my Factory 19"s. I like the idea of these being a lot lighter and will work with my new tyres. Now I think the Nissan centre bore is 66mm and the ford is like 73.1mm but I am sure I can use come centre bore spacers? Stud pattern is - 5x114.3Fronts - 19 x 8 +33 Rear - 19 x 8.5 +35 will be looking to fit my 245/35-R19 Falken Fk510 thoughts? excuse my sh*tty Photoshop lol Link to comment Share on other sites More sharing options...
E85XR6TURBO New Member 5 Member For: 9y 8m 10d Posted 09/08/19 02:57 AM Share Posted 09/08/19 02:57 AM (edited) Hi guys looking at purchasing wheels for my FPV and just like to check if 35 front offset will clear brembos. Thankyou. Edited 09/08/19 02:58 AM by E85XR6TURBO Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,176 Member For: 16y 9m 18d Gender: Male Location: Melbourne Posted 09/08/19 02:58 AM Share Posted 09/08/19 02:58 AM what width wheels and what model car and which specific wheels (as the shape of wheels can cause issues with brembo calipers) Link to comment Share on other sites More sharing options...
