Vigilance99 Member 30 Member For: 6y 2m 3d Posted 20/01/19 11:47 PM Share Posted 20/01/19 11:47 PM Hey does anyone know recommended fg falcon stud sizing ? Thanks! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 20/01/19 11:54 PM Share Posted 20/01/19 11:54 PM stock. Link to comment Share on other sites More sharing options...
Vigilance99 Member 30 Member For: 6y 2m 3d Posted 20/01/19 11:58 PM Share Posted 20/01/19 11:58 PM What are the measurements though? (5x 114.3)? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 20/01/19 11:58 PM Share Posted 20/01/19 11:58 PM yep, 5x114.3 is the stock stud pattern. Link to comment Share on other sites More sharing options...
Stefan428 New Member 2 Member For: 5y 11m 18d Posted 19/02/19 12:30 AM Share Posted 19/02/19 12:30 AM Hi there. Sorry if this is a stupid question. I have just bought a 2005 Ford Falcon XR6t, I love it. I'm looking to put 19 X 10.5 with a 22 ( don't know if its + or - ) offset,rims on the rear and a 19 X 9.5 with 22 offset on the front. Do you guys know if these will fit without having to alter the gaurds? and if you have had any experience in how they will make the car handle, eg wander etc , Thanks very much, Stefan Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 19/02/19 12:44 AM Share Posted 19/02/19 12:44 AM first of all, your car's not an FG, but it's OK... the same principles apply 10.5's will definitely not fit with a 22 offset without significant guard work... https://www.willtheyfit.com/index.php?width=245&aspect=35&diameter=19&wheelwidth=8&offset=37&width2=275&aspect2=30&wheel_size=19&wheel_width=10-5&offset2=22 check the measurements for how much space between the existing wheel/tyre and the suspension strut and the space between the wheel/tyre and guard and see if the values on that link above will fit. Then rinse+repeat with the fronts (change the values of the "width" and "offset" on the "new setup" part to suit the "fronts" in this case). Link to comment Share on other sites More sharing options...
Stefan428 New Member 2 Member For: 5y 11m 18d Posted 19/02/19 12:56 AM Share Posted 19/02/19 12:56 AM Thanks mate Link to comment Share on other sites More sharing options...
Vigilance99 Member 30 Member For: 6y 2m 3d Posted 02/03/19 11:39 PM Share Posted 02/03/19 11:39 PM just wondering will 20x 9.5 vertini dyn fit on a fg sedan with 275/30/20 tyre? What’s the widest you can go also cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,198 Member For: 16y 9m 26d Gender: Male Location: Melbourne Posted 02/03/19 11:44 PM Share Posted 02/03/19 11:44 PM yes, it will, assuming the offsets are compatible. Link to comment Share on other sites More sharing options...
Jumbuck Member 25 Member For: 5y 11m 28d Gender: Male Location: Melbourne Posted 11/03/19 08:48 AM Share Posted 11/03/19 08:48 AM Hi, I am ordering some Work wheels in 19 x 8.5 for the front on my sedan. Vehicle is only a few mm lower than stock. If I order in factory offset at 36.5 would they fit fine? Or should I adjust the offset slightly towards the outer guard to account for the minor increase in wheel size. Going to use the super pro rear control arm so the rear wheel specs have already been reccomended by super pro. thanks Link to comment Share on other sites More sharing options...
