  • Member For: 11y 7m 30d
Is a 19" rim, 9" wide with 35 offset okay front and rear on my g6et which is also on super low Springs? A local shop has a set of four that I'm thinking about, probably would have preferred 8.5s on the front but the wheels are a good price
Edited by karlp2
  • Member For: 8y 11m 29d
What type of look are u after?
Tucked in the gaurd?
Flush finish?
Whats the guard hight from ground to top of arch lowered?
35 offset is standard size so only 7mm wider each side from standard rims fg rims.
Google willtheyfit.com as fill in the numbers for a guide
Edited by BAXRTUTE
  • Member For: 11y 10m 22d
Did lol. 12.5mm each side (or 12.7 if you're pedantic)
Expand
Stock height 18x9 +29 (yours will sink in 6mm more). It will be close to the front suspension, but should be fine with 245s max. Below has 245/265s.
  • 3 weeks later...
  • Member For: 17y 4m 23d
  • XR50T
  • Member For: 11y 11m 15d
I want to go wider all around, mainly for more grip, more brake clearance and it should look pretty tough.
Currently have, front: 18x8.75 +36, 255/40r18. Rears: 18x9.75 +36, 295/35r18 but want to go as wide as possible without having to flare the guards, wouldn't mind rolling/pumping them though.
Fronts at the moment have roughly 25mm from the tyre to the guard but biger all room to the upright. Going by will they fit the new setup should be veeery close to the front guards.
I'm looking to fit 19x9.5 +20, 275/35r19.
Rears should be fine depending on brake clearance 19x11 +45, 325/30r19.
Tyre sizes are whats available in invos, would prefer 265 front and 315 rear but invos are usually pretty common.
Any ideas/opinions?
