  • Member For: 11y 11m 27d
my major question now is how are you fitting 17x10+38 without hitting bolt or control blade??? lol  and like the comment about running 9s    :spoton:
18x9+29 below....I think needs 10mm more poke on front for more flush (that pic is stock height and would tuck a tiny bit depending on how low you went and how much negative camber you wanna run - I stick to OEM with -0.5*).
Some are content with a bit of tuck....will look sweet either way. Did they give you any indication on wheel weight and kg load rating? For the coin you're spending, Advan also make quality lightweight forged wheels too  ;)  hahaha wish I had that budget to play with wheels lol and I hear ya about decisions....you should factor in a few hundred for opticoat or similar...personally im a fan of darker colour wheels so matte grey is my vote. I'd also be doing the typical black/white theme I.e. panda eyes black, rear diffuser black and roof wrapped black.
  • All stock bar the k&n panel filter
  • Member For: 13y 2m 9d
  On 08/06/2016 at 11:44 PM, PTR_NITRO_FG said:
...but needed rear spacer mod apparently (im guessing the 295s might rub control blade).
Expand
Correct. 10mm control blade spacer and all good from a rubbing perspective. Does present engineering issues if you don't offset the bush ring to compensate, though.
  • Member For: 14y 4m 6d
haha its got the power there to run a 9 and the driveline.. has been a 10.3 on less power and in December. Which I hot in central QLD. haha with 17x10 +38 one needs to put their big boy pants on and get the grinder out haha didnt take much but they do fit... just...  +29 looks like it would suit my needs!
hes going to get back to me on wheel weight once I decide wheel size. not sure on load rating either. ill find that out before purchase.
think ill go with gunmetal grey with polished lip
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 13d
Expand
Gonna need pics + details :spoton:
built motor/zf gtx4298 all the usual supporting mods.. 850rwkw on 33psi. normally run it on 750rwkw at 24psi.. Reason for different rims on dyno is they are nice wide but really old hard tyres.
  • Like 3
