nelsonian101 Donating Members 961 Member For: 16y 6m 25d Gender: Male Location: Sydney Posted 03/07/14 07:53 AM Share Posted 03/07/14 07:53 AM With a 285 on a 10.5" rear you would want to keep the offset at 35 or higher I would think! Even at +35 you would have 32mm less inner clearance and the rim would protrude from the guard very slightly.With an offset higher than 35 the problem is the inner rim doesn't clear on 18's. Fine for 19s and 20s though.My front and rear guards are rolled. 3.5 neg camber front and 2 neg rear. Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 6m 11d Gender: Male Location: OZ Posted 06/07/14 12:26 AM Share Posted 06/07/14 12:26 AM You mentioned a 10.5 front and 10 rear, this right? What offset you reckon you'll need with a 10.5? You'll just have a bit of poke that's all. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 6m 25d Gender: Male Location: Sydney Posted 07/07/14 07:34 AM Share Posted 07/07/14 07:34 AM My track rims are already 18 X 9.5 +22 front and rear. 275 35 18" tyres.Front offset would be around +22 with the 10.5" rims too.Fronts have heaps of clearance with the camber. With 0.5 deg neg camber they did scrape on the inner guards though.With 3.5 neg on the front as I have on my track set up, 285 30 18 all round should work on 10.5" 18" rims. Touching the brake ducting is always a problem on my car and lock to lock steering is no longer possible, so compromises have to be made for performance.I then have access to some A050's, or do the State Time Attack round in Clubsprint class with some 285/30 18 RS3's or similar.Power steering system is stressed with the extra width too but I just change the synthetic power steering fluid more often.But you are right, front does have some poke! Link to comment Share on other sites More sharing options...
fraserc New Member 24 Member For: 11y 2m 6d Gender: Male Location: Sydney Posted 18/07/14 02:52 AM Share Posted 18/07/14 02:52 AM (edited) Stupid/basic question, should 19x8.5 +28 fronts and 19x9.5 +30 rears on 245/35R19s and 275/35R19s be fine on stock suspension/when it eventually gets dropped a little?Cheers guys Edited 18/07/14 02:53 AM by fraserc Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 8m 3d Gender: Male Location: adelaide hills- 'race air' central Posted 18/07/14 10:18 AM Share Posted 18/07/14 10:18 AM rears may be a little aggressive for lowered springs. roll and slightly pump the guards for some flush goodness. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 23d Gender: Male Location: Perth Posted 18/07/14 01:04 PM Share Posted 18/07/14 01:04 PM yeh between +30 and +40 would be better Link to comment Share on other sites More sharing options...
DY 93 WA Member 49 Member For: 10y 8m 13d Gender: Male Location: perth, wa Posted 20/07/14 09:46 AM Share Posted 20/07/14 09:46 AM Hi just bought a fg mk2 xr6t and need help with offset choice for rpf1's.Have the option of 19x9.5 +22 or 19x10 +22 or 19x10 +25 for rears Preferably no guard rolling, also best option for fronts? Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 10m 6d Gender: Male Location: Perth Posted 20/07/14 09:54 AM Share Posted 20/07/14 09:54 AM I reckon your guards would be munching your tyres with the 19x10 +22 or 19x10 +25, based on the current research I've been doing...unless it's a ute...in which case, I have no idea... Link to comment Share on other sites More sharing options...
mummba Member 525 Member For: 14y 10m 13d Gender: Male Location: perth Posted 20/07/14 09:57 AM Share Posted 20/07/14 09:57 AM (edited) all depends on what tyre size you will be running and where you want the wheel to sit in relation to the guard.. all though's wheel specs will fit depending on tyre, though 19 x10 +25 with a 255 tyre front and rear fits no guard work and lowered...sedan Edited 20/07/14 09:59 AM by mummba Link to comment Share on other sites More sharing options...
DY 93 WA Member 49 Member For: 10y 8m 13d Gender: Male Location: perth, wa Posted 20/07/14 09:59 AM Share Posted 20/07/14 09:59 AM (edited) Yeah it's a sedan, thought it would, 19x9.5 +22 would be good for rears though? Would like 275 on rears Edited 20/07/14 10:00 AM by DY 93 WA Link to comment Share on other sites More sharing options...
