  • Member For: 12y 7m 29d
Ok, So if I didn't need longer bolts would those shims be what I need? Or can anyone suggest a good place to get the correct ones from?
  • Member For: 15y
Take your car to a suspension shop who already have the shims and get them to do the job.
They know what's needed and will do the alignment at the same time.
  • Member For: 11y 8m 12d
  On 23/11/2013 at 5:02 AM, The Kerb Warrior said:
Sorry like I said im not overly knowledgeable when it comes to cambers etc. Would this be the kind of thing im after?
http://www.ebay.com.au/itm/SUPERPRO-FORD-FALCON-AU-1-2-3-BA-BF-FG-FRONT-CAMBER-CASTOR-SHIM-KIT-3MM-/271246333676?pt=AU_Car_Parts_Accessories&hash=item3f278a96ec
When you go for a wheel alignment they will have the shims and it's part of the alignment mate.
  • Member For: 13y 3m 4d
You say that vixen but I took my car for a full alignment at jax and they told me there was no camber adjustment available (coz the bolts werent long enough apparently) so they only adjusted the castor and toe and I still paid full price, $77 I think. I suppose it depends on where u go.
Sent from my GT-I9300T using Tapatalk
  • Member For: 14y 7m 5d
Jax tyres charge $66 for a wheel alignment and this only includes any basic adjustments is toe adjustment. Any additional camber correction is charged at an hourly rate for thei time. Having shimmed the car up myself its fair enough cause its a a bit of a sh*t job to do!
As the for the stock bolts being long enough, I have sssl front springs with completely shimmed bolts and have less than -1 deg camber so if anyone tells you the bolts aren't long enough then that doesn't sound right
  • Member For: 17y 2m 5d
  On 18/11/2013 at 1:55 AM, vixenf6 said:
Will
19 x 9 +20
or
19 x 10.5 +25
fit and look good with out rolling or guard work on a FG Ute ?
Would need some tire stretch. 10.5+30 with 325's juuuuust Touchs on bumps.
  • New Member
  • Member For: 11y 6m 3d
Here I go first post...
Does anyone know if the Enkei PF01 (or RPF1) in the following wheel and tyre size
18 x 8.5 + 30 F (245/40)
18 x 9.5 + 45 R (275/35)
Will fit on a SC'd FG GT? I want to switch to a light 18" all black rim on my next tyre change to maximise handling and these seem the go.
Cheers
Edited by dl86
  • Member For: 12y 9m 6d
Cheers
Fronts would be ok but I am not sure about the rear, it will go about 28mm further in than a std 18x8 +36 which I think may hit the control blade bolt/mount.
A +36 or less in the rear would clear, could someone else confirm???
  • Member For: 15y
Cheers
No they'll only fit if you take the blower off:)
I've been told by 2 places that to fix 2-2.5 degrees negative camber I'll need a camber kit, more than just some shims. I'm hearing different things everywhere and just wanna get this sorted, anyone know a really good tyre place in perth?
