Bellato Donating Members 2,713 Member For: 14y 7m 1d Posted 07/11/13 11:11 AM Share Posted 07/11/13 11:11 AM Yes, but depends on what offsets you choose. +30 all round should be close to what you need Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1438687 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 2m 24d Gender: Male Location: Perth Posted 07/11/13 09:07 PM Share Posted 07/11/13 09:07 PM Forgot to put that in, +32. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1438760 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 1d Posted 09/11/13 01:55 AM Share Posted 09/11/13 01:55 AM Rear's will be fine, fronts may be an issue. The wheel itself will fit, not sure if you'll get a 265 on though, Have a look at the thread 275's all round by nelsonian, that might give you some ideas of inner clearance and probably even send him a PM to see what he suggests Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439021 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 2m 24d Gender: Male Location: Perth Posted 10/11/13 02:22 AM Share Posted 10/11/13 02:22 AM On 09/11/2013 at 1:55 AM, Bellato said: Rear's will be fine, fronts may be an issue. The wheel itself will fit, not sure if you'll get a 265 on though, Have a look at the thread 275's all round by nelsonian, that might give you some ideas of inner clearance and probably even send him a PM to see what he suggestsCheers mateWorst case you reckon 255's will fit? Or even 245? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439165 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 1d Posted 10/11/13 03:07 AM Share Posted 10/11/13 03:07 AM I'd say 245 will fit for sure. If I can get 245/35/20 +34 in no worries on 8.5" wheel then you shouldn't have an issue with the same width tyre only slightly wider rim. 255 and 265 will probably fit too it will probably depend on tyres brands though Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439170 Share on other sites More sharing options...
The Kerb Warrior Donating Members 612 Member For: 12y 7m 24d Gender: Male Location: Perth, Western Australia Posted 10/11/13 02:18 PM Share Posted 10/11/13 02:18 PM Just a quick question on the topic of offsets etc. Got a set of dark argent copies - 20 inch. 245's all round, currently running a 245/30/20 tyre. I've had some tyre places tell me running a 245/35/20 could set the car off, making it think theres something wrong and flip the traction control out? I've heard it could possibly cause damage. I've also heard that 245/35 will be fine, and probably be even better.Can anyone explain? Cause 245/35 are a lot easier to get a hold of than 245/30... Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439289 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 24d Gender: Male Location: Far north queensland Posted 10/11/13 08:45 PM Share Posted 10/11/13 08:45 PM all 4 tyres the same size = winyou can program the tyre size into the ecu, pick the closest one to make things peachy Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439298 Share on other sites More sharing options...
bandblightfoot Member 183 Member For: 12y 4m 18d Gender: Male Location: Gold Coast Posted 10/11/13 11:37 PM Share Posted 10/11/13 11:37 PM I run 245/35/20 to get a bit better ride only thing is that the rolling diameter is 24mm larger so speedo is out just used to gps to compensate and figure it out. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439320 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 1d Posted 11/11/13 12:25 AM Share Posted 11/11/13 12:25 AM On 10/11/2013 at 2:18 PM, The Kerb Warrior said: Just a quick question on the topic of offsets etc. Got a set of dark argent copies - 20 inch. 245's all round, currently running a 245/30/20 tyre. I've had some tyre places tell me running a 245/35/20 could set the car off, making it think theres something wrong and flip the traction control out? I've heard it could possibly cause damage. I've also heard that 245/35 will be fine, and probably be even better.Can anyone explain? Cause 245/35 are a lot easier to get a hold of than 245/30...If you're in a B series then you can't change tyre anyway because fronts can't fit the 35 profile. If FG then go for it, there are dozens of people on here with that size tyre including myself, only problem is my speedo being out a little. When doing 100 im doing 103, not a big deal, just something I compensate for when going through speed cameras Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439327 Share on other sites More sharing options...
The Kerb Warrior Donating Members 612 Member For: 12y 7m 24d Gender: Male Location: Perth, Western Australia Posted 11/11/13 09:16 AM Share Posted 11/11/13 09:16 AM Yeah its an FG.So with it apparently needing to be a 245/30, theres no issue being a 245/35? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/229/#findComment-1439404 Share on other sites More sharing options...
