  • 2 weeks later...
  • Member For: 13y 3m 5d
After numerous post's in this thread and others. I finally got some wheels.. ***LOTS OF PICS :)***
Ended up with what I originally wanted when I first bought my car, varrstoen 2.2.2's 19x9.5 +22 all round
Fitted the rears up, Poked about 3mm on the top (was hard to get it accurate but with no tyres)
Fronts followed, due to how low it sits there is heaps of camber so they tucked in about 5mm at the top
Tyres were fitted. 245/35 Federel 595 EVO's all round
Fronts had heaps of clearance, rears however caused an issue under load..
Borrowed a gaurd roller and spent the afternoon perfecting the rears
I knew that just rolling them might no give me the clearance I needed, so I decided to pump them also, they are pumped about 5mm, You can see the new body line about an inch and a half between the rear bumper and rear gaurd join
Same angle as before, Heaps of clearance now
Sits nice now, fronts could do with a 5mm spacer but at the moment im happy with the fitment
Should also note I have xsport coilovers.
  • Like 2
  • 570Nm @1800rpm
  • Member For: 21y 8m 9d
Any pictures of the entire car?
Should have left the rear dust plates on to hide those rusty rotors :)
Edited by XtRmn8
  • Member For: 12y 1m 20d
Yeah paint the rotor hats the rust don't look good. dunno why ford skimped on painting the rear rotors. Would've been cheaper than the dust cover
Looks good btw
Edited by vxr50t
  • 570Nm @1800rpm
I am running a 20x10 +40 with 275/30 rubber on SSL and not even close to rubbing. Even with two in people in the back (SSSL height), still no rubbing.
I think I am lucky in a way that the tyres (ATR 2s) are pretty narrow for a 275 and have a bit of stretch on the 10inch rim. If the tyres sat more "square", guards would need to be rolled.
