  • Member For: 16y 8m 1d
  On 18/09/2013 at 12:28 PM, fr33r said:
20 x 9 and 35 offset will be touch and go on the front. Will most likely hit on the inside. Would be ok on the back. This is a link to my 20x9 +32 with the same tyre you have.
Thanks mate did you end up running a 3-5mm spacer or downsize the tyre
Cheers
  • Member For: 13y 6m 15d
20x9+18 - king spring front springs ssl
20x10 +18 - king spring ssl leafs and 1" block in rear (rear guards been pumped slightly so could fit 15mm spacers)
post-48739-0-87004800-1379935231_thumb.j
post-48739-0-90018400-1379935235_thumb.j
post-48739-0-52913200-1379935239_thumb.j
  • Member For: 11y 8m 8d
I know this have been answered before but I just read through all the posts and now im confused. I know you can make 18x9.5 or 19x9.5 wheels fit the fg all around. but what offsets should they be to fit the front with a stretched tyre? id like all four tyres pretty flush to edge. car is not lowered.
Edited by jgbender
  • Member For: 15y 8d
So if you left em at +18 with no spacers you'd have no trouble with clearance on the rear when dumped? Interesting thanks evo.
That's correct mate, got plenty of clearance with no spacers and guard pump.
The fronts scrub on bumps though, may need skinner front tyres, currently have 245/35/20 on front.
  • Member For: 15y 2m 28d
will fit easily, especially with a stretched tyre...18s have room to play with in tyre selection to get them behind the guards as apposed to 20's
Edited by mummba
  • Member For: 12y 19d
Firstly, sorry guys I'm sure this has been asked and I would look through the past threads but I need to order today, bit of a rush
Fg f6 ute
20 x 8.5 front
20 x 10 rear
I'm after the most flush/filled out guard look possible without having to roll or pump the guards
What is my best choice for a custom off set?
I can get between +30 down to +15 on, but he said the +15 probably would need guards rolled
Stock height at the moment but want to lower ASAP not stupid low but a tough stance
Thanks heaps in advance!
  • Member For: 14y 7m 14d
You won't get flush unless you roll guards. In the front with ssl springs and rolled guards you'll get +20 with a 245/35 tyre and that's flush!
Same goes for the rear, you'd need rolled guards. If you remove the support and pump the guards properly I think you can get away with +20 offset aswell! Someone confirm the rears though cause I don't know utes that well
