mrdatsun21 Donating Members 17 Member For: 14y 10m 28d Gender: Male Location: Perth Posted 06/09/13 01:02 PM Share Posted 06/09/13 01:02 PM Couple quick questions. FG XR6 turbo sedan.19 x 9 +35 front19 x 10 +35 rear.Running bilstien shocks and SSL king springs all round. Will I have to do any guard work? What size tyres can I run without scrubbing etc?I only ask as I was told that running 10s on the back of a sedan can cause problems with scrubbing etc.Cheers Lads. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1422019 Share on other sites More sharing options...
fr33r Donating Members 92 Member For: 12y 9m 13d Gender: Male Location: Riverina NSW Posted 06/09/13 01:14 PM Share Posted 06/09/13 01:14 PM Fronts will be close on the inside but you should be ok with 19s. Rears will be close to flush, might be ok with a bit of stretch on the tyre and the ssl springs. If you had a choice, +30 front and +40 rear would be safer... Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1422021 Share on other sites More sharing options...
mrdatsun21 Donating Members 17 Member For: 14y 10m 28d Gender: Male Location: Perth Posted 06/09/13 01:23 PM Share Posted 06/09/13 01:23 PM Yeah that's the only offsets they offer which is a real pain. But it's the same with all the wheels I've looked at. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1422023 Share on other sites More sharing options...
mrdatsun21 Donating Members 17 Member For: 14y 10m 28d Gender: Male Location: Perth Posted 06/09/13 01:28 PM Share Posted 06/09/13 01:28 PM They do have a 9.5 in a +30 and +45. How would they go on the rear? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1422024 Share on other sites More sharing options...
fr33r Donating Members 92 Member For: 12y 9m 13d Gender: Male Location: Riverina NSW Posted 08/09/13 01:52 PM Share Posted 08/09/13 01:52 PM (edited) On 06/09/2013 at 1:28 PM, mrdatsun21 said: They do have a 9.5 in a +30 and +45. How would they go on the rear? The +30 x9.5 will only be 1.5mm difference from the +35 10inch, still flush. The +45 might be better but you will have more stance at the front. The +35 x9 front will sit about 15mm wider than std. The +45 rear will sit 11mm wider. Not much but just so you know. Wheels and offsets are a head ache... Sent from my HTC One XL using Tapatalk 4 Edited 08/09/13 01:59 PM by fr33r Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1422670 Share on other sites More sharing options...
mrdatsun21 Donating Members 17 Member For: 14y 10m 28d Gender: Male Location: Perth Posted 09/09/13 11:39 AM Share Posted 09/09/13 11:39 AM Ok cool. So what problems have people run into fitting 10's under the back? Where will they scrub or hit? How people have gotten around it? I was told that the spot that the 10's will hit is the clip that the rear bumper attaches to the body that's inside the rear of the wheel arch. Is that the case or is there anywhere else? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1423116 Share on other sites More sharing options...
fletty Member 191 Member For: 13y 3m 6d Gender: Male Posted 10/09/13 12:05 AM Share Posted 10/09/13 12:05 AM PM mummba, he can check inner clearance for you with his 10 +25's On 30/07/2013 at 10:36 AM, mummba said: does look sick!! im running 19x10 +25 all round on my sedan Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1423338 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 20d Posted 10/09/13 01:24 PM Share Posted 10/09/13 01:24 PM Mrdatsun its the lower trailing arm that can foul on the inside of the rim but mainly for 18s. With larger ones the bolts for the lower trailing arm sit inside the rim and don't foul Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1423664 Share on other sites More sharing options...
scorsto Member 40 Member For: 16y 7m 30d Posted 18/09/13 11:28 AM Share Posted 18/09/13 11:28 AM Picking up a GTE and have some 20 x 9 and 35 offsetTyres on front are 245 x 35 and rears are 275 x 30.Car has standard suspension at the moment will these fit?Cheers scorsto Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1426270 Share on other sites More sharing options...
fr33r Donating Members 92 Member For: 12y 9m 13d Gender: Male Location: Riverina NSW Posted 18/09/13 12:28 PM Share Posted 18/09/13 12:28 PM On 18/09/2013 at 11:28 AM, scorsto said: Picking up a GTE and have some 20 x 9 and 35 offsetTyres on front are 245 x 35 and rears are 275 x 30.Car has standard suspension at the moment will these fit?Cheers scorsto20 x 9 and 35 offset will be touch and go on the front. Will most likely hit on the inside. Would be ok on the back. This is a link to my 20x9 +32 with the same tyre you have. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/223/#findComment-1426274 Share on other sites More sharing options...
