EF-MattyB Member 30 Member For: 12y 8m 12d Posted 13/08/13 09:10 PM Share Posted 13/08/13 09:10 PM (edited) Hey guys,Been through this thread a few times now but just wanted to ask first and double check.I have a 2010 Fg XR6 Turbo UTE. I am looking at a set of Rota Grids in the following size/offsets:- Front - 19x9 +20 (245-35-19 ATR's)- Rear - 19x10 +10 (275-30-19 ATR's) This is the one I am worried about!!!Will these fit without any guard work?The car is stock height at the moment but I will be lowering slightly in the future....maybe SSL front and lowering blocks/reset rear.There are also some others on there (8.5 and 9.5) that I can get custom made to the offsets I want. Im guessing this might be my best bet???Any assistance will be greatly appreciated as I dont want to hit buy and them not fit within the guards!!!!Cheers Matt Edited 13/08/13 09:13 PM by EF-MattyB Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1415653 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 5d Gender: Male Location: Vic Posted 14/08/13 12:47 AM Share Posted 14/08/13 12:47 AM They will juuuuust fit. So close its not funny, but it would be better to play it safer. Varstoen 10.5 +35 will do the job. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1415693 Share on other sites More sharing options...
EF-MattyB Member 30 Member For: 12y 8m 12d Posted 14/08/13 10:17 PM Share Posted 14/08/13 10:17 PM Got in contact with ROTA directly and had the following response:Yes they’d be absolutely fine – our most common fitment for FG ute is 9.5 +20 front and 10.5 +15 rear!We can supply this fitment from AU stock in the GRID style 19x9.5 +20 / 19x10.5 +15.Just to double check, if a +10 was pushing it, a +15 should be ok?If so I will be purchasing these next week.Also, ideal tyre sizes will be 245-35 Front and 275-30 rears? Note I will most probably be using ATR as I have had these before and rate them.Cheers Matt Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1415972 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 7m 3d Gender: Male Posted 14/08/13 10:57 PM Share Posted 14/08/13 10:57 PM Yes those offsets on a ute will work...+15 will look mint on a FG ute Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1415976 Share on other sites More sharing options...
JordanByrneJ07 Member 62 Member For: 12y 5m 27d Gender: Male Location: Gold Coast, QLD Posted 15/08/13 10:44 PM Share Posted 15/08/13 10:44 PM I got 19x10.5 +12 on the rear of my ute, and I had to do some rolling/pumping. id say +15 should sit nice! Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1416233 Share on other sites More sharing options...
EF-MattyB Member 30 Member For: 12y 8m 12d Posted 16/08/13 08:43 PM Share Posted 16/08/13 08:43 PM On 15/08/2013 at 10:44 PM, JordanByrneJ07 said: I got 19x10.5 +12 on the rear of my ute, and I had to do some rolling/pumping. id say +15 should sit nice!Oh.....I really didnt want to have to touch the guards at all. Looks like I should hit him up for a safer offset. Maybe a +20 or +25 in a 10.5"? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1416477 Share on other sites More sharing options...
Alion Member 27 Member For: 17y 2m 4d Gender: Male Location: Figtree, Wollongong, NSW, 2525 Posted 17/08/13 12:37 PM Share Posted 17/08/13 12:37 PM Hey Guys,I know this question would of been asked here and I have spent time going through it, but it can be hard to find the best answer. Have an 09 G6ET and would like to go with 19's just for there grip over 20's (I know there wont be much extra). I still wont rule out 20's if it gets me 20mm extra in the rearSo the wants.I don't need the deep dish from small offsets but rather the tires fit perfect no rub.19' or 20'Fronts 245/255Largest rears possible I have seen 305 but I was thinking for good fitment 275 or a size larger? (car is getting high end diff bushes and looking into a locker)I just need the offsets and the tire sizes that they are able to run please!(sorry to ask a question I know there is an answer somewhere on here) Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1416699 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 6d Posted 18/08/13 01:59 AM Share Posted 18/08/13 01:59 AM Only point going 19's over 20's is if you're going to run a higher profile. So 275/35/19 over 275/30/20. You will get more grip that way.On the front you can go between +30 and +35 in an 8.5" wide wheel safely with a 245 and most likely a 255. Even in 20'sAs for the rear if you want 10" wide +40, if 9.5 then you can still go +40 but can go between +35 and +40 and still fit comfortably.Also you'll get more grip out of a 275/35 than a 305/25 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1416765 Share on other sites More sharing options...
naddis01 Member 49 Member For: 18y 1m 29d Gender: Male Posted 18/08/13 01:04 PM Share Posted 18/08/13 01:04 PM (edited) On 18/08/2013 at 1:59 AM, Bellato said: Also you'll get more grip out of a 275/35 than a 305/25Can you please explain why that would be the case? I assume because the diametre is much smaller than the 275.Edit: Why would you go a 305/25? Is that what people run when they got 305's? Wouldn't 305/30 be better? Edited 18/08/13 01:11 PM by naddis01 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1416941 Share on other sites More sharing options...
JordanByrneJ07 Member 62 Member For: 12y 5m 27d Gender: Male Location: Gold Coast, QLD Posted 18/08/13 10:35 PM Share Posted 18/08/13 10:35 PM On 16/08/2013 at 8:43 PM, EF-MattyB said: Oh.....I really didnt want to have to touch the guards at all. Looks like I should hit him up for a safer offset. Maybe a +20 or +25 in a 10.5"?I would say +15 would be enough clearance,My ute is pretty slammed - just depends on how low you are? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/221/#findComment-1416975 Share on other sites More sharing options...
