Fg Offsets And Tyre Questions
Dillz
  • flame magnet
  • Member For: 16y 8m 1d
@giantlobster: 9.5 +35 is way safe in the guard. id be thinking +25 at least for decent flush...
  • Member For: 16y 2m 27d
thanks panda u reckon that needs guard work? if I go +25 at the rear the front will be noticeably out of place being +33 but that's as far as the 8.5 will go. unless I go 9.5 at the front but im not sure if 9.5 @ +25 or +35 with fit the front without guard or camber work
@gaintlobster,also 8.5 +20 for front is nice and flush,+33 is poo
have you tried import monster?
yeah unfortunately I agree with ya but that's as far out as the 8.5 will go. unless I can find a way to have a 9.5 safely in the front without guard or camber work. yeah I did look at import monster they had some good prices on some and not for others. I assume you had good experiences with them?
  • flame magnet
front +33 with a 10mm spacer will look good. remember though that increasing the track will likely make it illegal and thus defectable.
I recommend rolling the rear guards for clearance with extra loads/ passengers etc.
fronts are already rolled from factory (on b series at least).
yeah that's true but if +33 plus 10mm spacer will fit without scrub then I may be able to get around it by choosing the +25 rim if available (not as good as panda is suggesting but close enough). and panda's right there is a limit to how much you can increase the track. I think going from +36 (FG factory, someone correct me if I am wrong) to +25 should be just within the legal maximum of 25mm allowable increase in track measured from mid tyre to mid tyre.
