Bellato Donating Members 2,713 Member For: 14y 7m 5d Posted 24/05/13 10:55 PM Share Posted 24/05/13 10:55 PM On 24/05/2013 at 1:02 PM, naddis01 said: Ok guys, I just got myself a new FG mkII XR6T sedan. I have started reading this thread but 2000 posts takes a while.I am probably looking at a 19x8.5 and 19x10 combination running 245/35/19 and 285/30/19. What offset range should I be looking at to sit close to the guards but not foul on them and without rolling? I'm not interested in doing work to the guards or running spacers etc. Is it possible to get a 10" rim with a 285 on the rear of an FG sedan without guard rolling or suspension clearance issues?Also why does everyone seem to run 275 on the rear when 285/30/19 are a better match to 245/35/19?On rear you want +40! As long as you don't go really low then you will be able to get a 275/30 on the rear (prob even 35 profile) without any guard work. Once you go to 285 then just a roll and slight pump will clear.As for the fronts anywhere between +25 and +35 is generally pretty safe. The +35 will be super safe even if the car is lowered heaps. +25 should work even with a bit of low, just might need the inner plastic moulded out a little (maybe, it should be right without it)Here's a calculator I found to work out overall rolling diameter. ((width x profile(%) x 2) + (wheel diameter x 25.4)So doing this a 245/35/19 = 654.1mm rolling diameter and 275/30/19 = 647.6mm. Now a 285/30/19 = 653.6mm. So going off that a 245/35 and 285/30 is the same so yes a 285 would be better. I think you might have read a lot of posts that people run 275/30 on a 20" wheelAt the end of the day though these are just rough figures and I've heard of differences in width of a 275 tyre being up to 20mm wider than each other because different brands have different shoulders etc.So when shopping around probably consider the width of the actual tyre when choosing between 275 and 285 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1392571 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 12d Posted 24/05/13 11:47 PM Share Posted 24/05/13 11:47 PM Bellato 10 +36 is the same as 9.5 +30 that's why I went with those but +40 will fit too.There isn't much to gain rolling FG rear maybe 1 to 2mm.My rear tyres are closer to a 295 even though it says 285, when measured its 292mm.Sent from my GT-I9300 using Motorculture mobile app Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1392586 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 5d Posted 25/05/13 12:05 AM Share Posted 25/05/13 12:05 AM Yea I agree but you're safer to run a higher offset (even if its only by 4mm) to avoid having to do guard workI reckon there's more to be had in fg guards than people make out. There's not as much as n series but I got at least 5-10mm doing mine Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1392591 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 12d Posted 25/05/13 12:46 AM Share Posted 25/05/13 12:46 AM You rolled your own guards bellato? I got PhillB from jdmst to do mine and there really wasn't much there to roll.I asked him to take it as far as he could without cracking the paint but would be hard to judge the limit unless you have a temp gun for the paint.Sent from my GT-I9300 using Motorculture mobile app Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1392598 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 5d Posted 25/05/13 06:01 AM Share Posted 25/05/13 06:01 AM Nah man got a shop to do them. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1392682 Share on other sites More sharing options...
evo Member 33 Member For: 13y 6m 6d Gender: Male Location: East Suburbs, VIC Posted 31/05/13 01:18 PM Share Posted 31/05/13 01:18 PM (edited) just bought some wheels from USA, fedex over in 4 days, sh*ts over auspost lolpics to come soon when this rain pisses off, specs are:20x9 +18 front - test fitted, lil bit of poke but no tyres fitted yet so wasn't a true measure.20x10 +18 rear - sits in around 15mm or so, no tyres either so wasn't a true measure (might use bolt on spacers if needed)Going on fpv f6 fg ute sneak peak picture attached...black gloss, multi spoke concave, 20"x10"+18 wheel Edited 31/05/13 01:26 PM by evo 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1394603 Share on other sites More sharing options...
mummba Member 525 Member For: 15y 2m 18d Gender: Male Location: perth Posted 31/05/13 11:40 PM Share Posted 31/05/13 11:40 PM nice mate be sure to post pics once on.. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1394678 Share on other sites More sharing options...
FGED UP Member 28 Member For: 13y 11m 17d Gender: Male Posted 01/06/13 01:15 AM Share Posted 01/06/13 01:15 AM would a 19x11 +30 fit on the rear fg ute with305 tyre Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1394699 Share on other sites More sharing options...
evo Member 33 Member For: 13y 6m 6d Gender: Male Location: East Suburbs, VIC Posted 02/06/13 06:24 AM Share Posted 02/06/13 06:24 AM (edited) On 31/05/2013 at 11:40 PM, mummba said: nice mate be sure to post pics once on..as requested mate although I need to lower it in the rear more. I have kingspring FOR-303SL in them, should I reset the standard leaf springs? I have them in the shed still..I think it has Ultra Lows (aka SSL) in the front.removed mud flaps while the wheels were off. wheels specs below...20x9 +18 front with 245/35/2020x10 + 18 rear with 275/30/20 Edited 02/06/13 06:37 AM by evo 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1395084 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 4m 15d Gender: Male Posted 02/06/13 07:21 AM Share Posted 02/06/13 07:21 AM nice ride there evo!Would a 18 x 255/40 fit on a 9.5"? Thinking of 18 x 8.5 +20-30 running 255/40 on front and then swapping to 18 x 9.5 +30 on the rear to finish them off (just the tyre obviously not rotating rims). Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/199/#findComment-1395096 Share on other sites More sharing options...
