Bulletime Donating Members 937 Member For: 14y 4m 19d Gender: Male Posted 23/05/13 10:06 AM Share Posted 23/05/13 10:06 AM Lots of good info thanks guys.Yeah bellato I'm def more concerned with handling and performance than looks, don't want it looking like a turd though but yeah.18 x 8.5 + 30 and 18 x 9.5 +35 (or less? how much less) prob sounds the way to go... might have to see what tirerack would cost or see if those ebay shops can get them in since they have bit much of a skyline focus... Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392174 Share on other sites More sharing options...
mummba Member 525 Member For: 15y 2m 22d Gender: Male Location: perth Posted 23/05/13 10:17 AM Share Posted 23/05/13 10:17 AM ive got 19x10+25 with a 255 tyre on the front of my fg and only have 3mm of clearance to the control arm,if you consider 19's anyways Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392177 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 17d Posted 23/05/13 10:49 AM Share Posted 23/05/13 10:49 AM (edited) spot on bellato, that's why I was recommending the 9.5s as well. its a gamble going too wide with 18s for rear unless you can test fit the rim you're planning on buyingbullet, 18x 9.5 + 30 are the magic numbers for rear. it will be dead flush with the rear guard and plenty of inner clearancefront offset I'd go 8.5 +20 if possible (or close to it). they''ll poke the same as mine which is 9 +26 (with -1deg camber)mummba, how much camber are you running up front? does it rub on the inner guard on full lock? Edited 23/05/13 10:54 AM by vxr50t Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392190 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 4m 19d Gender: Male Posted 23/05/13 11:26 AM Share Posted 23/05/13 11:26 AM On 23/05/2013 at 10:49 AM, vxr50t said: spot on bellato, that's why I was recommending the 9.5s as well. its a gamble going too wide with 18s for rear unless you can test fit the rim you're planning on buyingbullet, 18x 9.5 + 30 are the magic numbers for rear. it will be dead flush with the rear guard and plenty of inner clearancefront offset I'd go 8.5 +20 if possible (or close to it). they''ll poke the same as mine which is 9 +26 (with -1deg camber)20130523_204054.jpgmummba, how much camber are you running up front? does it rub on the inner guard on full lock?sweet thanks 18 x 9.5 +30 on the rear is what I'll aim for and I'll see how I go with 8.5 +20-26 fronts. Prob a little way away getting them but I'm really liking these which should clear brembos too http://www.tirerack.com/wheels/WheelCloseUpServlet?target=wheelCloseUp&wheelMake=Enkei+Racing&wheelModel=PF01&wheelFinish=Bright+Silver+Paint&tab=wheels Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392203 Share on other sites More sharing options...
FIXR7 Member 116 Member For: 15y 3d Gender: Male Location: Perth Posted 23/05/13 12:20 PM Share Posted 23/05/13 12:20 PM Aaah that's better... Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392225 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 17d Posted 23/05/13 12:29 PM Share Posted 23/05/13 12:29 PM the enkeis are nice but sizing is very limitedhave you considered work kiwamis? (new cr kai) they do 18x9.5 +30 deep concave face and I think they clear brembosI know scatterbrain runs 18x9.5 +30 all round and it clears on his BF. check this post:http://www.fordxr6turbo.com/forum/topic/83426-18-x-95-30-front-of-fg/would be worth asking scatterbrain and nelsonian if he got around to fitting them on the frontsif the fronts fit, you could run the same size tyre all round and rotate your tyres which is another bonus Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392229 Share on other sites More sharing options...
fgfalcon01 Donating Members 89 Member For: 12y 11m 28d Gender: Male Location: Brisbane Posted 24/05/13 05:36 AM Share Posted 24/05/13 05:36 AM Hey guys would a 275/40r20 fit under the back of an fg sedan. What would be the best offset to run with it? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392387 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 4m 19d Gender: Male Posted 24/05/13 09:05 AM Share Posted 24/05/13 09:05 AM On 23/05/2013 at 12:29 PM, vxr50t said: the enkeis are nice but sizing is very limitedhave you considered work kiwamis? (new cr kai) they do 18x9.5 +30 deep concave face and I think they clear brembosI know scatterbrain runs 18x9.5 +30 all round and it clears on his BF. check this post:http://www.fordxr6turbo.com/forum/topic/83426-18-x-95-30-front-of-fg/would be worth asking scatterbrain and nelsonian if he got around to fitting them on the frontsif the fronts fit, you could run the same size tyre all round and rotate your tyres which is another bonusthey're very nice, quite similar to the PF01, I might look into them a bit cheers! Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392442 Share on other sites More sharing options...
naddis01 Member 49 Member For: 18y 2m 2d Gender: Male Posted 24/05/13 01:02 PM Share Posted 24/05/13 01:02 PM Ok guys, I just got myself a new FG mkII XR6T sedan. I have started reading this thread but 2000 posts takes a while.I am probably looking at a 19x8.5 and 19x10 combination running 245/35/19 and 285/30/19. What offset range should I be looking at to sit close to the guards but not foul on them and without rolling? I'm not interested in doing work to the guards or running spacers etc. Is it possible to get a 10" rim with a 285 on the rear of an FG sedan without guard rolling or suspension clearance issues?Also why does everyone seem to run 275 on the rear when 285/30/19 are a better match to 245/35/19? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392517 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 17d Posted 24/05/13 01:21 PM Share Posted 24/05/13 01:21 PM (edited) No worries bullet. You might wanna try jdmconcept he does specials from time to time on nissansilvia.com .Naddis you're after 8.5 +20 & 10 +36 or +38 Dunno why ppl run 275 either, maybe the brand of tyre they want doesn't come in 285. I have 10s on mine with +33 on 285s but my tyres have wide sidewalls so they stick out even with nearly -2deg camber. Sent from my GT-I9300 using Motorculture mobile app Edited 24/05/13 01:27 PM by vxr50t Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/198/#findComment-1392522 Share on other sites More sharing options...
