fletty Member 191 Member For: 13y 2m 27d Gender: Male Posted 03/05/13 05:13 AM Share Posted 03/05/13 05:13 AM On 03/05/2013 at 12:14 AM, Bellato said: I think it could work with a bit of guard work and some negative camber and a 275 but like I said that's just a guess.Is there a rep nearby that can let you test fit? Haha unfortuneatly not, im 5+ hours from any city, downside of living in the country. On 03/05/2013 at 12:48 AM, MA91CK said: Fletty, I don't care. People making excuses cause you have a sedan, I don't care what you have. It'll fit. You want it to fit youll make it fit. You wana know why? BECAUSE RACECAR. haha just kidding.The biggest I can think of under a sedan would be worms with the 10.5 rears. 275 on an 11 is alootttt of stretch. Don't get me wrong, I'm all for it. But it has to be done right. There's a point where too much lip pole out from the tyre and looks stupid. In an ideal world of wana have 10.5 and 11 rears, about 10 different offsets and 275,285,295's to see whic combo looks truly flush or the best!Haha fair call. 11's would defineatly be pushing it, 285's may be a better options, but clearance issues on the inner gaurd may be a problem? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386068 Share on other sites More sharing options...
fletty Member 191 Member For: 13y 2m 27d Gender: Male Posted 03/05/13 05:47 AM Share Posted 03/05/13 05:47 AM 275/30 on 11" rim.. Ive seen worse? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386073 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 4d Posted 03/05/13 06:10 AM Share Posted 03/05/13 06:10 AM Yea I've seen worse lolI had 255/35 on a 10inch and it was stretched just as much if not more than that and it was fine.Given a 275 is meant to be 20mm wider give or take an an 11inch rim is 25mm wider I can't see there being much of an issue9.5's with 245 up front and 11's with 275 on the rear. Stretch should match that way Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386077 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 7m 4d Posted 03/05/13 12:22 PM Share Posted 03/05/13 12:22 PM Anyone know where I can get 15mm bolt on spacers? I found heaps with right centre bore size but different thread types and can't be effed running different wheel nuts front and rear Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386166 Share on other sites More sharing options...
CHLAXN Donating Members 932 Member For: 17y 1d Gender: Male Location: north QLD Posted 03/05/13 12:22 PM Share Posted 03/05/13 12:22 PM Got a question will a 18x10 -1 offset fit on rear of a fg ute? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386167 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1d Gender: Male Location: Wollongong Posted 03/05/13 01:14 PM Share Posted 03/05/13 01:14 PM On 03/05/2013 at 12:22 PM, CHLAXN said: Got a question will a 18x10 -1 offset fit on rear of a fg ute?Think I know what wheels your looking at will be a fat fitment, don't think it'll fit without rolling though. Even then may need a little stretch if lowered more than 2" That 275 looks pretty good actually, must be a good tyre. Thought it would stretch heaps more than that? I think ill go 275 then, that's the kinda stretch I was after. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386172 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 13y 1d Gender: Male Location: Wollongong Posted 03/05/13 01:16 PM Share Posted 03/05/13 01:16 PM And I rekon an 11 would fit under an fg sedan, roll and pump. Will poke a little but aww baby would it be tough. +25 should be close. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386175 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 10m 28d Gender: Male Location: Sydney Posted 03/05/13 11:10 PM Share Posted 03/05/13 11:10 PM Who thinks I can fit 275/35 18 all round on my FG sedan?Wheels are SSR Type C 18 X 9.5" with +22 0ffset.Here are some pics with my current tyres, some 2nd hand Michelin slicks. 250 front, 270 rear.Tyres will be Hankook Z214 Grooved slicks. On their way as we speak from tire rack.Rear guards have been rolled and with 1.5 deg of neg camber, rears should just tuck under the guards.In theory, I am hoping the fronts will be fine.I have tested a 18 X 9.5 +30 with a 265 on front and it seemed to clear in the carpark, but with 1 deg of neg camber, bot the 3.5deg I run at the circuit.As stock FRONT offset is +36 with a 245 tyre (on 8" rim), a 275 will only poke out 15mm further in but due to offset (36 vs 22), should be only 1mm difference.Does this make sense?Hoping I don't need a 3 or 5mm spacer and longer studs. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386227 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 7d Gender: Male Location: adelaide hills- 'race air' central Posted 03/05/13 11:43 PM Share Posted 03/05/13 11:43 PM better pics wud be gud... Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386235 Share on other sites More sharing options...
fletty Member 191 Member For: 13y 2m 27d Gender: Male Posted 04/05/13 04:32 AM Share Posted 04/05/13 04:32 AM On 03/05/2013 at 1:16 PM, MA91CK said: And I rekon an 11 would fit under an fg sedan, roll and pump. Will poke a little but aww baby would it be tough. +25 should be close.I would really like to confirm it will fit before purchasing, Gaurds are getting rolled this week, wont be getting pumped unless I absolutely have to, I quite like the stretch look of the 275 on the 11 as it's the look im going for. These dont come out until the end of may so I still have plenty of time to get it sorted and make sure it's what I want. Can anyone help with the fitment on the inner gaurd for the rears? Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/189/#findComment-1386290 Share on other sites More sharing options...
