  • Member For: 14y 7m 12d
  On 01/11/2012 at 1:02 AM, Adrian6T said:
Guys,
Im looking at wheels for my FGII GS sedan lowered on SSL fronts and SSSL rears.
I would like 20x9 on the front and 20x10 or 10.5 on the rear.
The offsets available for the front are +20, +32
The offsets available for the rear are +45 for the 10" and 10.5"
Will the fronts be too wide offset and rub?
Are the rear offsets too far in?
Fronts should be good at +32 but you got no chance with a +45 on the rear in a 10 or 10.5. In a 10 your pushing it with +42.
  On 01/11/2012 at 2:34 AM, TRA1NR said:
Yes mate, +32's, rubbed on the inner guard at the front, on full lock and when I hit big bumps. With the 30's I have not had either, and they are a +25.
Okay sweet, cause I have +42 offset on the front and just seeing how much I can push it out to fit a 245/35 with no dramas. I basically only want to push it out far enough form the control arm to fit the tyre so I can stay far enough in from the guards. I'm think about a 5 mm spacer (so +37) should do the trick?
  • T.P.I.S.
  • Member For: 20y 5m 28d
I wonder what this guy used then?
You can get a +25 for the rear but nothing between +25 and +45 as the site says
Edited by Adrian6T
  • Member For: 14y 10m 4d
Guys,
. I would be going +20 fronts and the rears should fit ! But I don't have a sedan will they hit on the inside (rears) anybody with a sedan? Edited by j.d
  • Member For: 14y 9m 12d
  On 01/11/2012 at 5:51 AM, Adrian6T said:
What about a +25 for the rear. Apparently that's what the GT in the pic is running.
No way +25 on the rear..
If theyre 10's id say +35-40
9.5 to 10 inch rims will be +35-40 that's it on the rear.
It sure does look good
  • T.P.I.S.
  On 01/11/2012 at 5:55 AM, j.d said:
Will poke, u will need to run stretched Tyres
The pic above of the GT above seemed to fit fine.
  • Pitlane Member
  • Member For: 18y 30d
it could be +45 with spacers, maybe contact tech 9 and ask about that car?
Trainers got a point! Plus you have a BF and there's less room standard I believe, might need some heavy guard work to make it all fit
And J.d I have a FG sedan and my 20x10 +38 have eff all room as it is, and my diff is centred, could squeeze maybe a +40 but then would be pushing it with the tyre, would need a little stretch
