Corzza 777 Member 7,135 Member For: 16y 2m 5d Gender: Male Location: Neutral Bay. Born and Bred in the RSA Posted 27/09/12 08:39 PM Share Posted 27/09/12 08:39 PM On 27/09/2012 at 1:25 PM, samcaula13 said: Suppose I should ask again.So I've found a nice of 19's to buy. They have tires already - but I'm waiting to hear back about the off-set tomorrow.They're 9" Fronts 245's, 10" Rears 265's. I've asked for a general run down on profile and offset as to determine how they'll fit (if at all) - but I was under the impression that depending on what size wheel you go (19-20") you can go wider.Sorry if I come across like a complete newb - I have read quite a bit of this thread already... and I've noticed quite a few people sticking very thick wheels in a 19/20" setup - with the exception tending to be 18's not being able to go as wide without poking or ridiculous off-sets. I just want to double and triple check before I spend my money - as I really don't want to accidentally purchase something that doesn't fit.On a side note - some of the cars in here look ridiculously good with the wheel choices. Neotim's black ute was a standout for me. Amazing.I got 245's in front and 285's rear with 35 offset all around and they fit. So if you play around with the offset you will get the stance you want. 25 front and 40 rear would work great Link to comment Share on other sites More sharing options...
samcaula13 Member 17 Member For: 12y 7m 7d Posted 27/09/12 09:35 PM Share Posted 27/09/12 09:35 PM Ahh okay that makes sense - thanks guys.Hypothetically - if I get these 19's - are there are any profiles or offsets that I should be wary of? Or are most sensible setups going to work just fine?I'll post the details here when I get them anyway. Link to comment Share on other sites More sharing options...
samcaula13 Member 17 Member For: 12y 7m 7d Posted 28/09/12 12:46 AM Share Posted 28/09/12 12:46 AM On 27/09/2012 at 8:39 PM, Corzza said: I got 245's in front and 285's rear with 35 offset all around and they fit. So if you play around with the offset you will get the stance you want. 25 front and 40 rear would work greatThis is where I am curious about offsets?When you say 'play around' with the offset - is there a way for me to change the offset on a particular set of wheels. Or is that done prior to payment/purchase. Say for example, I bought used wheels that had xx offset - is there a way for me to 'play around' with that setting, or am I stuck with whatever the manufacturer made? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 30d Gender: Male Location: SW Sydney Posted 28/09/12 01:09 AM Share Posted 28/09/12 01:09 AM If the wheels are a 2 or 3 piece then you can usually change the centres for a different offset, however if the wheel is forged or one piece then you have to choose the offset before buying Link to comment Share on other sites More sharing options...
Corzza 777 Member 7,135 Member For: 16y 2m 5d Gender: Male Location: Neutral Bay. Born and Bred in the RSA Posted 28/09/12 01:11 AM Share Posted 28/09/12 01:11 AM You can ask the dealer to provide rims with different offsets for you to try out but without the tyre you want on it you cant get an accurate look.The offset of a wheel is the distance from its hub mounting surface to the center line of the wheel. The offset can be one of three types (measured in millimeters).* Zero OffsetThe hub mounting surface is even with the centerline of the wheel. PositiveThe hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. NegativeThe hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle. Link to comment Share on other sites More sharing options...
samcaula13 Member 17 Member For: 12y 7m 7d Posted 28/09/12 01:25 AM Share Posted 28/09/12 01:25 AM Thanks for the help guys.Is that your car in the profile pic Corzza? If so, that's my next car - colour and everything. Link to comment Share on other sites More sharing options...
CHILLR Donating Members 186 Member For: 12y 7m Gender: Male Location: Doreen Posted 28/09/12 05:29 AM Share Posted 28/09/12 05:29 AM So im looking at some 20" Rohana RC5 rims for my FG GT.Front only come in 9" with an offset of 35. Are these things going to fit?....The Rears come in 9" and 10.5. Id like the widest tyre possible. Which should I go? Dam this wheel tyre business hurts me!... Just dont like the standard. Well I dont hate them but dont love them. Plus I need wider tread! Help :-) 1 Link to comment Share on other sites More sharing options...
samcaula13 Member 17 Member For: 12y 7m 7d Posted 28/09/12 09:31 AM Share Posted 28/09/12 09:31 AM So I have a bit more information regarding the 19's.They're BSA wheels, 245/35/19 Fronts: 265/30/19 Rears.Apparently around +35 offset. Used to sit on a skyline (same 5 stud pattern I assume?) He has been using them with a 25mm + 10mm bolt on spacer to fit an S14.So that does that sound reasonable to fit on a Falcon? I assume a wheel/tyre shop can remove the spacers and simply fit the wheels?Thanks. Link to comment Share on other sites More sharing options...
samcaula13 Member 17 Member For: 12y 7m 7d Posted 28/09/12 09:54 AM Share Posted 28/09/12 09:54 AM http://bsawheels.com.au/products_closeup.asp?part=G2&part_no=557That's them from what I can tell. Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 7m 18d Posted 28/09/12 01:34 PM Share Posted 28/09/12 01:34 PM Im almost certain Nissan and ford dont share the sane stud pattern. Link to comment Share on other sites More sharing options...
