STIFLR Donating Members 572 Member For: 16y 2m 2d Gender: Male Location: Victoria Posted 31/08/12 12:17 AM Share Posted 31/08/12 12:17 AM Have a look at Corzza's FG, it will sit like that. So probs wont be able to go as low as you wanted. 1 Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 22d Posted 31/08/12 01:05 AM Share Posted 31/08/12 01:05 AM Thanks Stiflr I forgot he had them too! Your right I won't be able to fit the rears without some guard work but Stiflr has 285/30 at the moment and fadz come with a 255 so with that much stretch I should be fine. Plus I can test fit them and see what they're like then get the guards pumped with my old rims on and then put the vertini's on once guard work is doneStill not 100% sure of Fadz's offsets yet though, +35 all round?Also has anyone ever increased they're offsets? Is it possible to shave a couple of mm off the inside of the wheel to get a higher offset or once the wheels are manufactured that's it Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 3m 19d Gender: Male Posted 31/08/12 07:28 AM Share Posted 31/08/12 07:28 AM There is a set for sale on Ebay, $1700 20x8.5+15 and 20x10+20. Falken tyres in black. Link to comment Share on other sites More sharing options...
cor33 Member 36 Member For: 12y 11m 9d Gender: Male Location: Brisbane Posted 31/08/12 08:10 PM Share Posted 31/08/12 08:10 PM same offset as mine Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 22d Posted 01/09/12 12:18 AM Share Posted 01/09/12 12:18 AM There is a set for sale on Ebay, $1700 20x8.5+15 and 20x10+20. Falken tyres in black.That's too aggressive of a fitment for what I'm after but pretty good price. I'm committed to buy fads' now, getting them 2moro!The offsets are 38 rear and 42 front! Rear is almost perfect but will still need some guard pumping, front is really high but I'll put a 5mm hub spacer if I want to bring them out more to put wider tyres on! Link to comment Share on other sites More sharing options...
Corzza 777 Member 7,135 Member For: 16y 9d Gender: Male Location: Neutral Bay. Born and Bred in the RSA Posted 01/09/12 03:28 AM Share Posted 01/09/12 03:28 AM Thanks Stiflr I forgot he had them too! Your right I won't be able to fit the rears without some guard work but Stiflr has 285/30 at the moment and fadz come with a 255 so with that much stretch I should be fine. Plus I can test fit them and see what they're like then get the guards pumped with my old rims on and then put the vertini's on once guard work is doneStill not 100% sure of Fadz's offsets yet though, +35 all round?Also has anyone ever increased they're offsets? Is it possible to shave a couple of mm off the inside of the wheel to get a higher offset or once the wheels are manufactured that's itYeah mate they are +35 all around. Bees dick clearance over the brembos. I rolled my guards as it was rubbing slightly on the right had rear. My cradle is off 3mm to the right. Other than that fit snug Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 10m 21d Gender: Male Location: Vic Posted 01/09/12 04:28 AM Share Posted 01/09/12 04:28 AM Same as JDs, needed a 5mm spacer to clear fronts. Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 22d Posted 01/09/12 06:12 AM Share Posted 01/09/12 06:12 AM Yeah mate they are +35 all around. Bees dick clearance over the brembos. I rolled my guards as it was rubbing slightly on the right had rear. My cradle is off 3mm to the right. Other than that fit snugSweet! If I remember correctly you had a about 7-8mm clearance to the control blade so at +38 I should be able to go 275/35 or 285/30 yea? Will definitely pump my guards because the cars gonna be lowSame as JDs, needed a 5mm spacer to clear fronts.Did JD have +35 all round or +42 front and +38 rear? These were his orange vertini's? Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 10m 21d Gender: Male Location: Vic Posted 01/09/12 06:29 AM Share Posted 01/09/12 06:29 AM +42 front and +38 rear. Iirc he ran a 35mm spacer all round. Link to comment Share on other sites More sharing options...
Corzza 777 Member 7,135 Member For: 16y 9d Gender: Male Location: Neutral Bay. Born and Bred in the RSA Posted 01/09/12 07:02 AM Share Posted 01/09/12 07:02 AM Sweet! If I remember correctly you had a about 7-8mm clearance to the control blade so at +38 I should be able to go 275/35 or 285/30 yea? Will definitely pump my guards because the cars gonna be lowYeah that's right around 7-8mm. +38 should be fine mate. I got 285's on mine at the moment no dramas Link to comment Share on other sites More sharing options...
