RynoF6 Idiot Member Donating Members 446 Member For: 15y 3m 24d Gender: Male Location: Muswellbrook, NSW Posted 26/09/11 11:30 AM Share Posted 26/09/11 11:30 AM (edited) Tocchi has used neg camber and suspension to tuck them in, works but will wear the tyres.Look up what your stock offset is. FG FPV are 19x8 +36.5.Use the calculator - http://www.willtheyfit.com/ and measure on the inside and outside of what you have stock and compare to what you have entered for new size in the calculator.that's what I did. Its harder for f6 and gt owners cause they also have to clear bigger brakes.As for the redrilling the pcd, the company I got them from are the dealer for the wheels so still under warranty. If you get done yourself be carefull. Edited 26/09/11 11:31 AM by RynoF6 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144202 Share on other sites More sharing options...
XXXRTURBO Donating Members 1,168 Member For: 17y 9m 11d Gender: Male Location: Melbourne Posted 26/09/11 11:39 AM Share Posted 26/09/11 11:39 AM I just bought 10's at the back by 8.5 on front will have pics in a couple of weeks :good: Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144203 Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 3m 24d Gender: Male Location: Muswellbrook, NSW Posted 26/09/11 11:41 AM Share Posted 26/09/11 11:41 AM These will help toohttp://www.1010tires.com/wheeloffsetcalculator.asphttp://www.rimsntires.com/specs.jspWhy you want mega wide front? There is some good tyres that give excellent grip. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144204 Share on other sites More sharing options...
shanerobertson Member 35 Member For: 14y 6m 13d Gender: Male Location: Geraldton W.A. Posted 26/09/11 11:53 AM Share Posted 26/09/11 11:53 AM Doesn't need to be so wide if they don't fit. The main problem is wheelspin on low throttle in 2nd and sometimes 3rd with 245's and ZF box so the rear is most important. So if 285's fit without mods and if Prodrive Performance parts come on line with mod Control Blades to allow 295 or 305 I'll smile.Thanks for the links, checking them out now. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144207 Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 3m 24d Gender: Male Location: Muswellbrook, NSW Posted 26/09/11 12:01 PM Share Posted 26/09/11 12:01 PM What type 245's? After the dunlop sp sport maxx junk I had yokohama advan v103's, gripped better on rear but still spun. Now run 275 and they grip good on a stock F6. When there gone I will go 255 front and 285 on these rims. 20's wont help you get you grip. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144209 Share on other sites More sharing options...
shanerobertson Member 35 Member For: 14y 6m 13d Gender: Male Location: Geraldton W.A. Posted 26/09/11 12:10 PM Share Posted 26/09/11 12:10 PM Running Goodyear F1 assemetrical 245/40/18 on the stock rims and they are so much better than the Dunlop's. But the prices in 20's with these width my prove to be a budget buster. So ideas are welcomed. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144211 Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 15y 11m 13d Gender: Male Location: Brisbane Posted 26/09/11 12:25 PM Share Posted 26/09/11 12:25 PM Well the widest tyre I've managed to fit under the front of my BF was 275/35/18, But that was with -3.5° of camber. However I previously had 265/35/18 on the front with only -1.0° camber. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144214 Share on other sites More sharing options...
shanerobertson Member 35 Member For: 14y 6m 13d Gender: Male Location: Geraldton W.A. Posted 26/09/11 01:43 PM Share Posted 26/09/11 01:43 PM I'm thinking that it's safer to not be too silly on the front now, maybe just 255. More than that seems to be to much trouble although I'd like more. As rynof6 said I'd be better off with better rubber rather than width. Tocchi on the forum has run 10" on the front but I can't find more than that. How did it fit? Plus BF front ends have a different suspension setup to the FG. And 20" reads different to 18".Do you cop alot of excessive inside wear with the camber? Or get the tyres rotated regularly? And what do you run with on the rear if you had 275 fronts?Maybe road legal semi slicks. It doesn't rain much here. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144216 Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 15y 11m 13d Gender: Male Location: Brisbane Posted 26/09/11 08:19 PM Share Posted 26/09/11 08:19 PM I ran 275 allround, they were race semi slicks (Dunlop DZ03g's $650 a coner). 70m out from a hairpin doing 180kph, stand on the brakes and they would just chirp once but never could lock them up. My next step is to try and fit Kumho V710 in a 285 uner the front. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144227 Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 8m 26d Posted 26/09/11 09:09 PM Share Posted 26/09/11 09:09 PM Be careful with camber. Ive been running 1.8 degrees up front till recently and the tyre were starting to feather on the inside edge. Just shimmed it out to bring it to a more respectable 1.1 degree neg camber. The wider the tyre the more wear youll encounter.. Link to comment https://www.fordxr6turbo.com/forum/topic/92946-fg-offsets-and-tyre-questions/page/10/#findComment-1144230 Share on other sites More sharing options...
