  • Member For: 14y 1m 16d
Gday guys
So I've recently installed a reinforced flex plate and I did a ZF service at the same time.
Just chucked it off the stands to take it for a drive. I am now stuck in third gear. When I flick it over to sports mode it flashes a 3 and in normal drive the D flashes.
I have a very sloppy gear stick selector now which was fine before and feels like I have gained another gear when going from D back to P. Sometimes its very rough as well, Like a banging sound if I don't push the stick back to P fast.
Here are some videos of what I am getting.
Can any one help me please?
https://www.fordxr6turbo.com/forum/topic/92918-stuck-in-third-gear/
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 6d
I don't think you have the selector on the box in the same location as the selector cable, I bet you've bumped it to a position other than P ( or wherever you left it ) and pulled the selector cable to re attach it again once finished.
Did you just unclip the selector cable end ( female ) from the male stud on the box selector or did you full undo and dismantle the cable selector assembly on removal ?
  • Like 2
  • skids
  • Member For: 12y 4m 9d
  • Gender: Not Telling
too many beers while doing the engine n box swap ayy
hows the other car? hahha.
isnt there some electronic business that needs done with the ZF with a swap like this?
  • Member For: 17y 5m 13d
He's too busy doing skids to reply after it worked again
Well I managed to get it sorted!
Turns out the bracket that holds the cable to the box has a washer but it goes BEHIND the bracket. This made the cable line up perfectly with the selector!
Thanks everyone for your help :)
  • Like 4
No worries buddy
#HahnSuperDry
