Abs light, no speedo, Hbrake light
Elturbo
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 5m 20d
Hey Elturbo - its just the way some of the guys with experience talk - don't take it to heart. When you meet them in person you'll realise they're a great bunch.  Should come on some cruises with us in your State if any are going ...
  • New Member
  • Member For: 8y 7m 21d
Im not taking it to heart so all good !
Thanks mate.
getting the coils done on wednesday so ill let you guys know how it goes
cheers
  • Like 2
  • New Member
Update guys ive just thrown some coils in it but in the mean time ive stupidly broken the small 90 degree rubber bend that joins the small hose/pipe from the rocker cover that goes into the crossover pipe (if you understand what I mean I dont know what its called?) is the car driveable/startable to check if ive fixed the problems with rough idle and so on?
I would assume its not safe so I wont start her.    dam :S
And ive just found another problem the hose clamp that joins the piping to the front of the turbo is complelty loose. Good as
Sorry just to make it a bit coearer the thin diameter plasticy pipe that runs on top on the throttle body with the plastic nut joining it to the crossover pipe is the one I broke.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 16d
That bit is just part of the PCV system. It can be disconnected no worries temporarily and just glue it back into place onto the crossover when you get a chance.
  • Trust me bro...tbh ;) 8===}
  • Member For: 9y 11m 28d
You can drive it. It will be fine. If you give it a flogging then expect that a small amount of oil will spill out.
Just get a screwdriver onto that turbo pipe clamp and tighten it up.
I actually have that rocker cover pipe just sitting around if you get stuck and can't source one. I don't have the short rubber bit but I have the longer plastic bit.
  • Like 2
