ML24 Member 33 Member For: 8y 8m 2d Posted 04/01/17 09:41 AM Share Posted 04/01/17 09:41 AM Hi All Has anyone got a boot lip spoiler (aftermarket/OEM) that is not the standard XR boot spoiler? If so, what are your thoughts? Can anyone who has done either of these already provide some info? I'd like to change mine to a simple lip spoiler like the G6E, but don't want to have to get a new boot/weld up holes/do bodywork etc: http://www.ebay.com.au/itm/FG-FALCON-G6E-BOBTAIL-SPOILER-/231394931610?hash=item35e036739a:g:ui0AAOSwj0NUasuS Alternative is this: http://www.ebay.com.au/itm/FORD-FG-FALCON-DJR-REAR-BOBTAIL-SPOILER-WITH-LED-UNPAINTED-/122060932387?hash=item1c6b660523:g:E6sAAOSwf-VWXpUX From some quick reading, the fitment isn't great and will still probably need a bodyshop to install along with prime/paint. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/ Share on other sites More sharing options...
damo6 Member 85 Member For: 12y 5m 10d Gender: Male Location: brisbane nth Posted 06/01/17 06:26 AM Share Posted 06/01/17 06:26 AM (edited) I had a djr briefly on my fg,changed my mind and put original back on,just didnt do it for me.piss easy to mount though,the hardest bit was threading the brake light wire down the guts of the spoiler thru a little hole on the underside.make sure to put felt under it or it will rub on the paintwork.it bolts up to the existing bolt holes,covers them completely.lines up perfectly too at least mine did. The only real drama I had was getting it painted by 3 different painters because they couldn't match the bastard paint Edited 06/01/17 06:29 AM by damo6 Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1627599 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 8m 15d Gender: Male Location: Mildura Posted 07/01/17 05:56 AM Share Posted 07/01/17 05:56 AM I've got a djr on my bf but I want to swap it back to the standard one already but I sold it haha Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1627696 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 4d Gender: Not Telling Location: Radioactive wasteland Posted 07/01/17 06:37 AM Share Posted 07/01/17 06:37 AM If you were closer I'd swap you. Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1627701 Share on other sites More sharing options...
Ben_BAXR6 Member 49 Member For: 8y 8m 20d Gender: Male Location: Adelaide Posted 07/01/17 08:42 AM Share Posted 07/01/17 08:42 AM I have a DJR on my BA, and the fitment is spot on. Was on the car when I bought it, so unsure if genuine or replica, but doubtful of genuine. Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1627714 Share on other sites More sharing options...
ML24 Member 33 Member For: 8y 8m 2d Posted 16/01/17 04:33 AM Author Share Posted 16/01/17 04:33 AM Has anyone gone spoiler-less? If so, what are you using to plug up the holes in the boot? If I were to go the smaller lip that will be held on with double sided tape, how can I plug the holes if I want to go back to stock spoiler later? Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1628480 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 4d Gender: Not Telling Location: Radioactive wasteland Posted 16/01/17 05:05 AM Share Posted 16/01/17 05:05 AM Supercrap auto or bunnings have plastic push on plugs. They look tacky but do the job if you put some silicon on the inside of the boot hole. The best option is to get an xt bootlid from the wreckers. Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1628486 Share on other sites More sharing options...
damo6 Member 85 Member For: 12y 5m 10d Gender: Male Location: brisbane nth Posted 18/01/17 06:45 PM Share Posted 18/01/17 06:45 PM Whats the legality if you remove the spoiler and have no centre brakelight? Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1628791 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 4d Gender: Not Telling Location: Radioactive wasteland Posted 18/01/17 09:02 PM Share Posted 18/01/17 09:02 PM It's illegal. Again off to the wreckers for an xt parcel tray light. Or you could get tricky with an led strip somewhere. Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1628794 Share on other sites More sharing options...
Ale Member 249 Member For: 13y 9m 29d Posted 18/01/17 10:54 PM Share Posted 18/01/17 10:54 PM You can just cut the carpet of the XR parcel shelf and fit the light from a spoiler less model easy enough. The parcel shelf carpet is just held onto the sheetmetal by xmas tree clips. Pull the wiring out from the bootlid, leave it in the boot and plug in the new light. I did it when fitting a force lip on a XR. The cops love defecting the Late model camira kids for no high level brake light . Link to comment https://www.fordxr6turbo.com/forum/topic/92812-boot-lip-spoilers/#findComment-1628798 Share on other sites More sharing options...
