skidxr6t skids Donating Members 2,754 Member For: 12y 5m 16d Gender: Not Telling Posted 21/12/16 08:09 AM Share Posted 21/12/16 08:09 AM but if wiring in standard globe to the led makes it work properly, then using the correct resistor would also work. Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1625970 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 20d Gender: Male Location: Probably above atmospheric pressure Posted 21/12/16 09:12 AM Share Posted 21/12/16 09:12 AM I thought that was commented on before, that there's a spike in resistance as it first heats up? I do recall reading ages ago that just the resistor does the trick though so I was surprised to read about it not working - maybe just wrong rating? Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1625972 Share on other sites More sharing options...
turbovich Member 32 Member For: 17y 6m 20d Gender: Male Location: CROATIA DUBROVNICK or Perth Posted 21/12/16 09:58 AM Share Posted 21/12/16 09:58 AM 2006 BF F6 I installed all below 2 1/2 years ago. No prob with c/c, abs, 'dim glow!.......etc. •Parkers 50w led. Plug n play •Reverse 80w led (1x 50w 6ohm resistor) •Brake/Tail light 50w led (2x 50w 6ohm resistor. 1 per tail light) •Number plate led. Plug n play. •Boot and int map/footwell,courtesy light all plug n play Indicators are factory. No reason, just cbf 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1625978 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 28d Gender: Male Location: adelaide hills- 'race air' central Posted 21/12/16 11:21 AM Author Share Posted 21/12/16 11:21 AM so maybe using the same 6ohm resisters that the led indicators require might work for the brake lights. worth a try. Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1625980 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 7m 4d Gender: Male Location: left right out Posted 22/12/16 07:03 AM Share Posted 22/12/16 07:03 AM As a slight aside, dont do the drink and buy online. I got a pair of H3 leds for the spots in my BF2 ( the phillips crystal vision H3 dont match the mains for colour ) What I failed to think of was the dirty great fan gizmo on the back of the LEDs wont fit in the spot lights plastic backing cup- FAIL! Looks like I will have to try the diamond vision halogens. As you were gentlemen Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1626039 Share on other sites More sharing options...
yenchy Donating Members 21 Member For: 13y 6m 24d Gender: Male Location: Ballarat, VIC Posted 26/12/16 05:20 AM Share Posted 26/12/16 05:20 AM These are the ones that I got: I used the reverse and indicators from this kit: http://www.ebay.com.au/itm/Ford-Falcon-AU-BA-BF-Bright-LED-Taillights-Brake-Reverse-Indicator-Bulbs-/181192029451?hash=item2a2fe2f50b&_uhb=1 and the stop/tail lights from this one: http://www.ebay.com.au/itm/Ford-Falcon-BA-BF-AU-HiPower-Red-Cree-LED-Tail-Brake-Light-Globes-Error-Free-/201117411545?hash=item2ed38828d9&_uhb=1 The indicators hyper flash and the reverse lights are on but dim (only noticeable at night or up close during the day) I currently have the incandescent globes in for the stop/tail lights as the issues I was having where as follows: -parker lights turning on when the brakes where applied -cruise control not activating -cruise control not turning on unless the brakes are being applied (and then turning off with no brakes) -faulty bulb alert (little light bulb in the trip computer flashing) I did not test to see if the abs was working but I have heard from people I trust (auto sparkies) that this can happen. The only two things I have tried is the shtty 5ohm 20 something watt resistors, that both suppliers had given me, and it didn't work for any of the globes and having an incandescent on one side and an led on the other which did work. I will try what @turbovich has done next and it would be good if you could remember where you had gotten them from. Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1626387 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,543 Member For: 17y 2m 3d Gender: Male Location: Melbourne Posted 26/12/16 05:40 AM Share Posted 26/12/16 05:40 AM ^^ this chump Trial and motherfarkin' error, it seems... Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1626389 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 15d Gender: Not Telling Posted 26/12/16 04:57 PM Share Posted 26/12/16 04:57 PM I've changed nothing and have no wiring issues nor gaf either. Problem solved!? Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1626434 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,543 Member For: 17y 2m 3d Gender: Male Location: Melbourne Posted 26/12/16 10:05 PM Share Posted 26/12/16 10:05 PM Solid plan, puffster! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92786-led-brake-globes-and-cruise-control/page/2/#findComment-1626438 Share on other sites More sharing options...
