  • Member For: 8y 5m 17d
Hi All,
I have read through the brake threads and studied the conversions. The 355 mm rotors and Brembos are very nice but a little hard to justify price on a BA street/work ute. My brakes are a total rebuild so the 300mm standard diameter rotor with slots seems a little pointless so I have arrived at what I think is the middle ground. 325 mm DBA slotted rotors with either my original calipers with new seals and the bracket kit or PBR Calipers Ford genuine or the variants I have seen. Can anyone comment on the differences on the two caliper choices?
https://www.fordxr6turbo.com/forum/topic/92769-not-another-ba-brake-thread/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 26d
you'd barely be able to notice a difference unless you went the full PBR kit, and even then, the difference would be minimal in terms of performance.
Just go with good quality pads and discs with better brake fluid with your stock brake setup and you'll be happy with that :spoton:
So to be clear I want go with 325mm Dba slotted rotors, my original calipers with a seal kit put through them with the new bracket to fit the larger rotor and Bendix premium pads, I think that will be a massive improvement on what I have now?
  • Site Developer
Unlikely to be an improvement if you're not increasing the surface area of the brake-pad contact. If you're going to upgrade the size of the rotors, always upgrade the calipers to suit, imho.
  • Site Developer
Ford spare parts can probably get you the PBR kit. Same with PBR themselves. Or you can get them from a wrecker for cheaper 2nd hand.
Cheers - :Welcome2FordXR6t:
  • Member For: 8y 11m 16d
  • Gender: Not Telling
What's the overall difference between the 2 pot caliper on my BF to the c6 2 pot caliper?
Piston size?
Those pbr m series calipers are :drool:
  • XR50T
  • Member For: 12y 5d
Race brakes Sydney do the kit you lot speak of, he's also doing a big brake set to fit in the standard 19s using a bigger more rigid PBR caliper.
  • 3 weeks later...
  • To Loud
  • Member For: 13y 5m 5d
I think it may be to late to mention this, but I will in any case.
Don't forget to get braided lines. that also makes a big difference when it comes to brakes.
You don't get the spongy feel. that was the biggest thing I hated when I got the car.
