skidxr6t skids Donating Members 2,754 Member For: 12y 4m 15d Gender: Not Telling Posted 16/12/16 11:21 PM Share Posted 16/12/16 11:21 PM (edited) the 2nd gear kickdown is awesome, I do it all the time man. at 80-90km/h having the thing go into 2nd is unreal hahahaha. had some very scary moments on roads I thought were dry and grippy but were not. worst was one time in the wet on the freeway with easily 10-20+ witnesses who would have seen the car fully kick out hahahahahaa - lucky I was on the on ramp. it shifts harder than it needs to in low load conditions. no slip or unusual noises except one issue is when its cold the rpm bounces up and down by a few hundred revs if im cruising at 50-60 in 4th - I usually put it in performance so it stays in 3rd for longer and it's fine once warmed up. been meaning to get the fluid done actually. it's also cool the way it shifts when you floor it and go through 1-2-3-4....oooh man I just want one of them fancy circle d converters fitted!!!!!!!!!!!!!!!!!!!!!!!!!!! dynoed 360kw oct last yearbut should get it thrown up again. was scary as fark when tailshaft quit life and killed the front section, donut bush and transmission output flange as the tow truck driver said 'hmmm probably your input shaft mate' Edited 16/12/16 11:23 PM by skidxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625567 Share on other sites More sharing options...
Lthlwpn Member 29 Member For: 8y 6m 19d Gender: Male Posted 16/12/16 11:37 PM Author Share Posted 16/12/16 11:37 PM On 16/12/2016 at 11:21 PM, skidxr6t said: the 2nd gear kickdown is awesome, I do it all the time man. at 80-90km/h having the thing go into 2nd is unreal hahahaha. had some very scary moments on roads I thought were dry and grippy but were not. worst was one time in the wet on the freeway with easily 10-20+ witnesses who would have seen the car fully kick out hahahahahaa - lucky I was on the on ramp. it shifts harder than it needs to in low load conditions. no slip or unusual noises except one issue is when its cold the rpm bounces up and down by a few hundred revs if im cruising at 50-60 in 4th - I usually put it in performance so it stays in 3rd for longer and it's fine once warmed up. been meaning to get the fluid done actually. it's also cool the way it shifts when you floor it and go through 1-2-3-4....oooh man I just want one of them fancy circle d converters fitted!!!!!!!!!!!!!!!!!!!!!!!!!!! dynoed 360kw oct last yearbut should get it thrown up again. was scary as fark when tailshaft quit life and killed the front section, donut bush and transmission output flange as the tow truck driver said 'hmmm probably your input shaft mate' Expand Cant wait to see what mine makes this time did heaps since last time Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625569 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 15d Gender: Not Telling Posted 16/12/16 11:42 PM Share Posted 16/12/16 11:42 PM yeah well hopefully in future you'll only be smashing drive line components after the transmission Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625570 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 4m 18d Gender: Male Location: Melbourne Posted 16/12/16 11:43 PM Share Posted 16/12/16 11:43 PM does monsta torque do a stage 3 like nizpro with the larger diameter shaft? Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625572 Share on other sites More sharing options...
Lthlwpn Member 29 Member For: 8y 6m 19d Gender: Male Posted 16/12/16 11:58 PM Author Share Posted 16/12/16 11:58 PM Not sure dude On 16/12/2016 at 11:42 PM, skidxr6t said: yeah well hopefully in future you'll only be smashing drive line components after the transmission Expand Lol I've got final drive chromoly tubing and beefyer center bearing tail shaft for it Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625574 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 15d Gender: Not Telling Posted 17/12/16 12:03 AM Share Posted 17/12/16 12:03 AM they did mine too, mechanic had me drop the shaft off there. not sure what they did do it other than paint it but I had a chat about the cars power level and was told 'leave it with me'. Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625576 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 17d Gender: Male Location: Perth Posted 17/12/16 01:25 AM Share Posted 17/12/16 01:25 AM Cryo treated shaft may in the end not have a material toughness greater than stock. All depends on how good the original heat treatment was. If you have the box apart just fit billet..... Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625580 Share on other sites More sharing options...
joe@cms Member 129 Member For: 15y 10m 29d Gender: Male Posted 17/12/16 02:26 AM Share Posted 17/12/16 02:26 AM If your in Perth Robby (Monsta torque) is the man..... also depending on your hp you may be better of with the ZF hybrid (mustang input shaft setup) and with all ZF's the key to its survival is 50% box & 50% tune.... BUT! if you are going to seriously abuse it or have no mechanical common sense then go 3 speed, with over 30 years of R&D & billet everything of the shelf a safe option for some ppl. Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625586 Share on other sites More sharing options...
Lthlwpn Member 29 Member For: 8y 6m 19d Gender: Male Posted 17/12/16 04:13 AM Author Share Posted 17/12/16 04:13 AM On 17/12/2016 at 12:03 AM, skidxr6t said: they did mine too, mechanic had me drop the shaft off there. not sure what they did do it other than paint it but I had a chat about the cars power level and was told 'leave it with me'. Expand If it was $990 for shaft then its the same as mine Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625600 Share on other sites More sharing options...
Lthlwpn Member 29 Member For: 8y 6m 19d Gender: Male Posted 17/12/16 04:25 AM Author Share Posted 17/12/16 04:25 AM On 17/12/2016 at 2:26 AM, joe@cms said: If your in Perth Robby (Monsta torque) is the man..... also depending on your hp you may be better of with the ZF hybrid (mustang input shaft setup) and with all ZF's the key to its survival is 50% box & 50% tune.... BUT! if you are going to seriously abuse it or have no mechanical common sense then go 3 speed, with over 30 years of R&D & billet everything of the shelf a safe option for some ppl. Expand Whats abuse I just wanna go drags now and then and and be able to use the kick down whats your recommendation Link to comment https://www.fordxr6turbo.com/forum/topic/92764-bad-zf-tunes/page/3/#findComment-1625601 Share on other sites More sharing options...
