skidxr6t skids Donating Members 2,754 Member For: 12y 4m Gender: Not Telling Posted 13/12/16 01:32 PM Share Posted 13/12/16 01:32 PM yeah your sct thing if its an xcal2, 3 or 4 will read codes 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92745-interior-lights-staying-on/page/3/#findComment-1625239 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,303 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 13/12/16 01:34 PM Share Posted 13/12/16 01:34 PM I don't know the specific wiring or I'd give you an answer straight up If everything is coming on then it seems that there is a common live wire and everything is switched by ground (or vice versa). Check from the start/power source/relay and find where it is earthing out. This is the simplest way to diagnose the issue but as I said I don't know how it is wired so there may be other things to take into consideration. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92745-interior-lights-staying-on/page/3/#findComment-1625240 Share on other sites More sharing options...
Ben_BAXR6 Member 49 Member For: 8y 6m 26d Gender: Male Location: Adelaide Posted 13/12/16 04:40 PM Author Share Posted 13/12/16 04:40 PM 3 hours ago, skidxr6t said: yeah your sct thing if its an xcal2, 3 or 4 will read codes Car is tuned with an SCT Xcal3, ill plug it in and have a geez later today. 3 hours ago, Puffwagon said: I don't know the specific wiring or I'd give you an answer straight up If everything is coming on then it seems that there is a common live wire and everything is switched by ground (or vice versa). Check from the start/power source/relay and find where it is earthing out. This is the simplest way to diagnose the issue but as I said I don't know how it is wired so there may be other things to take into consideration. I think its exactly like you say, and when the door closes it switches the lights off, so I'm looking at the door switch. Ill have a look at that again, it may just need adjusting or something. Cheers for the help boys, appreciate it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92745-interior-lights-staying-on/page/3/#findComment-1625243 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 6d Gender: Male Location: Canberra ACT Posted 13/12/16 11:20 PM Share Posted 13/12/16 11:20 PM I might be wrong, but if the door switch was faulty and not registering the door closing, wouldn't you also get the dash indicator and chime going off? 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92745-interior-lights-staying-on/page/3/#findComment-1625253 Share on other sites More sharing options...
Ben_BAXR6 Member 49 Member For: 8y 6m 26d Gender: Male Location: Adelaide Posted 14/12/16 12:32 AM Author Share Posted 14/12/16 12:32 AM That's what I thought too, but nothing. Just the lights on. ? Link to comment https://www.fordxr6turbo.com/forum/topic/92745-interior-lights-staying-on/page/3/#findComment-1625262 Share on other sites More sharing options...
Bara58 Donating Members 116 Member For: 12y 9m 11d Gender: Male Location: Bowen, Qld Posted 19/12/16 02:43 AM Share Posted 19/12/16 02:43 AM (edited) Wiring4 Electrical.pdf Has courtesy lights wiring on page 20 Edited 19/12/16 02:45 AM by Bara58 Link to comment https://www.fordxr6turbo.com/forum/topic/92745-interior-lights-staying-on/page/3/#findComment-1625729 Share on other sites More sharing options...
