ROB83R Member 1,632 Member For: 8y 11m 11d Gender: Not Telling Location: Radioactive wasteland Posted 16/12/16 05:28 AM Share Posted 16/12/16 05:28 AM Well you're set then. Hopefully the coils solve your issues. Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1625483 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 22d Gender: Male Location: Australia Posted 16/12/16 05:41 AM Author Share Posted 16/12/16 05:41 AM ECU finally threw a DTC saying misfire on cylinder 6 which is promising as that coilpack would be the one that gets the hottest. My battery terminals are also loose and can't be tightened anymore so that will be the next thing to look at if it doesn't. Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1625485 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 11m 11d Gender: Not Telling Location: Radioactive wasteland Posted 16/12/16 08:23 AM Share Posted 16/12/16 08:23 AM That's even better news. I think those terminals wouldn't cause the miss but maybe cause other issues. Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1625510 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 22d Gender: Male Location: Australia Posted 24/12/16 12:18 AM Author Share Posted 24/12/16 12:18 AM (edited) Ok new coils made the idle smoother but it still drops cylinder six for about a minute then comes perfect again, seems random but more common when hot. I'm guessing an electrical problem somewhere as if it was a head gasket or something the plug would look average (it didnt) and it would always be rough. Where would you look next? Loom looks good but could have an issue somewhere. I'll try giving the connectors a scrub and clean. Edited 24/12/16 12:18 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1626215 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 2d Gender: Not Telling Posted 24/12/16 12:30 AM Share Posted 24/12/16 12:30 AM (edited) id be whipping out a multimeter and testing resistance of certain wires, like the battery negative etc. after going around and cleaning battery terminals/connections etc. just note when using a multimeter that if you put the probes on to test a wire it only tests from the tip of each probe so make sure it has a good connection else you'll think everything has gone to crap lol. Edited 24/12/16 12:31 AM by skidxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1626217 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 24/12/16 02:26 AM Share Posted 24/12/16 02:26 AM could be a coil driver in the PCM... Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1626226 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 22d Gender: Male Location: Australia Posted 24/12/16 02:41 AM Author Share Posted 24/12/16 02:41 AM On 24/12/2016 at 2:26 AM, k31th said: could be a coil driver in the PCM... Expand You ever seen that happen before? Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1626230 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 24/12/16 03:29 AM Share Posted 24/12/16 03:29 AM Yeah... It's painful to diagnose. Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1626232 Share on other sites More sharing options...
sprouly07 Donating Members 62 Member For: 10y 9m 17d Gender: Male Location: Townsville Posted 12/02/17 09:34 AM Share Posted 12/02/17 09:34 AM Any updates on this? Having a very similar issue at the moment but am pretty sure it's just a voltage issue. Car will sit there for for 8 days while I'm out at work and when I get back my x4 says the system voltage is 11.8V. Start the car up and it sounds like a lumpy v8 for a minute and then comes good. Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1631485 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 22d Gender: Male Location: Australia Posted 12/02/17 10:03 AM Author Share Posted 12/02/17 10:03 AM Nope. Can't narrow it down. About to try another ecu with my tune flashed in to see if it's an ECU issue. Pretty much ready to crush the car as the clutch issue is unresolved as well after dropping the box and bench testing everything. Link to comment https://www.fordxr6turbo.com/forum/topic/92740-xr6t-dropping-a-cylinder-at-idle-when-hot/page/3/#findComment-1631489 Share on other sites More sharing options...
