discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 2d Gender: Male Location: Probably above atmospheric pressure Posted 05/12/16 03:38 PM Share Posted 05/12/16 03:38 PM (edited) Posting a separate thread to help anyone else that tries googling this or searching here. TLDR: My wheel is making a metallic squeaking noise each rotation, it's definitely not the bearings or brakes or ball joints. It was the wheel weights! Long version So the new wheels went on and all was well for about a week, then this started happening I went a bit crazy chasing it, I thought I had a dead wheel bearing at first and wasted time checking it - I do have bearings on the way out in the rear as I happened to find, but eventually I found that moving the wheel between the front and back also moved the sound, so it had to be specific to the wheel or tyre in question. I started to fear a cracked rim. The set were only a grand, but a new replacement would be about $900 retail.......not gonna happen. I had plastic hub centric rings installed and changed to metal ones once they arrived (ordered before the noise started) but they didn't fix it either. It's been very embarrassing rolling around in car parks and stopping at lights with this going on...just what you don't want when you're rocking new rims! Really killed the enjoyment. Tonight I got the missus to drive it back and forth with me walking along and listening, then spraying water at the wheel, which quietened it! Went for a drive in a 100 zone nearby and it returned, but I figured I could pinpoint the noise with this technique...the sun went down but it was a nice night so I busted out the LED work lights after dinner and started trying to "surgically" spray different parts of the rim. Centre, nuts, outer lip...but now it kept squeaking. Removed the metal hub centric rings and changed to brand new wheel nuts (handy to have spares) and still squeaking... I was looking for hairline cracks in the rim when I looked at the clip on wheel weight. I'd previously tried removing the stick on weights on the inner dish but had missed this one. Even looking at it closely I could see dust was missing at the edge. Upon prying it off I saw this: Look at that mark against the rim! I'm getting excited at this point but trying not to count my chickens before they hatch. Inspecting the 15g weight I see the inside edge is verrrrrrry shiny - unlike the rest of it. I stuck the hub centric ring and original wheel nuts back in and decided I was going to back myself and torqued up the wheel nuts to spec for the test drive instead of just guessing with the breaker bar for the short test drives I'd been going on up and down the driveway. Rolled out and...nothing I'll definitely need to get them rebalanced but a quick test drive at speeds up to 100kmh showed no perceptible change in feeling which was the icing on the cake. Edited 05/12/16 03:44 PM by -Stever- Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 1m 27d Gender: Male Location: WA, Perth Posted 05/01/17 05:35 AM Share Posted 05/01/17 05:35 AM Steve, where was it rubbing on? the brake caliper or the spindle/control arm? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 3d Gender: Male Location: Perth Posted 05/01/17 05:41 AM Share Posted 05/01/17 05:41 AM Can I post the screen shots of the several hundred msg Whatsapp convo's trying to work out what this was and the tremendous amount of shitpost suggestions that where included? 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,167 Member For: 16y 9m 17d Gender: Male Location: Melbourne Posted 05/01/17 05:43 AM Share Posted 05/01/17 05:43 AM whatsapp doesn't seem like the best place to get a technical question answered; but each to their own, I guess definitely post the sh*tposts, though, as they'd normally end up here anyway Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 2d Gender: Male Location: Probably above atmospheric pressure Posted 05/01/17 07:24 AM Author Share Posted 05/01/17 07:24 AM Ah well that depends on who is in the group... If I'm in it, I'll tell you where the noise is coming from very rapidly Since you seem to have missed the pics earlier, here they are again hahaha. Make sure imgur isn't blocked where you are... Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 1m 27d Gender: Male Location: WA, Perth Posted 05/01/17 07:29 AM Share Posted 05/01/17 07:29 AM okay, hold on for a sec. Rewind..... I have no issues viewing the pics. Imgur not blocked. Those are snap on weights for the inside of the rims right..... ? The clip to the inside/lips of the rim. If the weight is rubbing on the rim, then something must be pushing the damn weight on the other side....... I have to be missing something here. do you have a pic of when it was installed? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 2d Gender: Male Location: Probably above atmospheric pressure Posted 05/01/17 07:50 AM Author Share Posted 05/01/17 07:50 AM Logical suggestion I've had is rubber tyre is squishy and was pressing against it as it rotated. Noise happened as wheel turned to the same spot each time so I'd agree! I was sure the wheels were deforming hahaha 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 1m 27d Gender: Male Location: WA, Perth Posted 05/01/17 10:47 AM Share Posted 05/01/17 10:47 AM Cool, then that explains it. I was just worried it was rubbing somewhere. Link to comment Share on other sites More sharing options...
