Clutch disengagement issues
rollex
  • Member For: 8y 7m 15d
  • Gender: Not Telling
I may have missed the part where he checked the lines, mc and slave for leaks. You said it yourself it's strange how it's intermittent.
  • Member For: 10y 6m 26d
Ok got the car back and it is much much better but not perfect. I'm guessing the is just old syncros as they are still a tad notchy. However I get a clean reverse and first at the lights now, pedal feels much better as well.
If I clutch in and immediately go for first I still get a slight bump  if I wait a second it is fine. Clutch guy said due to the weight and size of the clutch assembly he isn't surprised it takes a second to spin down.
I guess this is as good as it will get. Kind of wish I got an auto now! Anyone want to trade? Lol
Edited by rollex
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 8m 24d
good result, rollaaaaaaaa :spoton:
The manual does feel "mechanical" but I like that about the car; it makes you feel more connected and in control of the big barge :)
  • 1 month later...
Ok so the problem is unresolved and getting worse. Randomly I get in the car and the clutch is half way to the floor, pump it 5x and it comes good. Usually after I drive to work and get in the car 2 hours later, almost completely on the floor.
No fluid is leaking and I can't see anywhere that air can be getting in.
Could it be something up with the new clutch master I put in, eg the piston is sticking or something?
Edited by rollex
Keefy just reminded me.
I get those symptoms or had those before in my xy. Tap the master cylinder lightly with a hammer and it may fix it. Sometimes the master will get stuck.
Gave it a good "tap" and it felt pretty good around the block, got a clean second everytime which was promising. Time will tell as its so inconsistent its hard to tell.
There you go man. New master cylinder.
In saying that mine hasn't failed in 3 years since the tap.
Now it'll phuck up when I go to move it next week.
