Lewis
  • New Member
  • Member For: 8y 9m 25d
Hi there.
I am suspect of the standard heat exchanger that cools the transmission on my FG Xr50 turbo ute.
I do not want to install a kit with wheel arch mounted radiator but would rather fit a quality heat exchanger that fits in the same spot as the standard item.
does any one know of such a thing and if so can someone point me in the right direction.
I am bout to drive from Sydney to Adelaide across the desert and want to not stress about the milkshake effect.
thanks
lewis
  • skids
  • Member For: 12y 2m 9d
  • Gender: Not Telling
man I just told my mechanic to throw a new standard replacement on with new coolant.
would test for stray current in the cooling system which is what I think could be responsible for premature failure.
if you replace every 40,000kms/2years it'll be fine.
  • Member For: 8y 9m 18d
I bought a kit that goes behind the intercooler for $190 and added a bit of hose so I could move it behind the fog light. Works a charm.
  • Member For: 8y 10m 19d
Mine was mounted there also, I had it fitted with the new cooler ans stuff at pbe.
Lewis,
I honestly have no idea on what one it is atm. Can find out by tomorrow arvo for ya though?
Its sitting in a work shop with a bunch of other stuff I pulled off the car.
If its compatible to the zf from btr which I cant see why not @JETURBO ill happily send it to u as ill be throwing it in the bin otherwise.
Edited by BAXRTUTE
It will need the right fittings for the box I think.
I think the btr has metal lines from the box to the radiator.
http://www.gumtree.com.au/s-ad/1115442376?utm_campaign=socialbuttons&utm_content=app_ios&utm_medium=social&utm_source=sms
this kit comes with 3m of hose you just need another 3 meters and a 5/8 male on male hose joiner or a new hose to bypass the coolant valve thingy under the inlet manifold.
Edited by ROB83R
