RJF6 Member 37 Member For: 8y 6m 27d Gender: Male Location: Wodonga Posted 25/11/16 08:59 PM Author Share Posted 25/11/16 08:59 PM Hey guys thanks for the replies, so I can feel fuel vibrating through the rail when it's priming, I will disconnect the return line and make sure today, with the sct plugged in it is reading rpm while cranking so a guess the cas is working, is there anything else that could cause it to lose injector pulse and spark? Left it for a few hours while I was at work, tried to start again no good, tried holding throttle to the floor to turn off injectors in case it was flooding, and nothing just keeps cranking not even a cough out of it Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1622834 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 8m 29d Gender: Male Location: Melbourne Posted 25/11/16 09:08 PM Share Posted 25/11/16 09:08 PM Slightly loose battery connector? I had a similar experience with my F6 after parking it and it would not start again on a cold night but dash lights lit up. Neg was loose on mine but still attached so just not enough current getting through but enough to power some eletricals. Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1622836 Share on other sites More sharing options...
RJF6 Member 37 Member For: 8y 6m 27d Gender: Male Location: Wodonga Posted 25/11/16 09:14 PM Author Share Posted 25/11/16 09:14 PM Did it turn over? Mine cranks fine just won't start Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1622837 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 8m 29d Gender: Male Location: Melbourne Posted 25/11/16 11:34 PM Share Posted 25/11/16 11:34 PM Its happened twice to me on same car. I don't remember well what happened. But second time didn't take me long to resolve as tightening battery connectors (after taking leads off completely to clear off any corrosion around terminals) worked. Maybe take battery to garage to check state of your battery? I've heard the F6 is sensitive to battery state because of its electricals. Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1622845 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 6d Gender: Not Telling Posted 25/11/16 11:52 PM Share Posted 25/11/16 11:52 PM maybe the ECU needs to cop a load of boiling water and you try and start the car Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1622849 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 1m 7d Posted 26/11/16 05:53 AM Share Posted 26/11/16 05:53 AM Just because you can get a rpm signal on your scan tool doesn't mean its good enough - had aV8 land cruiser this week ,no injector pulse, no spark ,no codes but I had a rpm signal on cranking- replaced the crank angle (position ) sensor & of it went ( was booked the next day for 'problem with the gas' but came in a day early on a tow truck ) 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1622929 Share on other sites More sharing options...
RJF6 Member 37 Member For: 8y 6m 27d Gender: Male Location: Wodonga Posted 28/11/16 01:31 AM Author Share Posted 28/11/16 01:31 AM (edited) got some time to look at it on Saturday morning and after pulling out a couple of spark plugs I noticed they were dry, so I got the wife out to turn the key while I had a screw driver between my ear and the fuel rail and nothing no flow, drained tank as it was full and removed pump, discovered the line from the pump to the lid(that the lines connect to) had broken off, So new fuel line in and off she went. I had mistaken some vibrations I felt in the rail while roadside as I sign of fuel flow and I was wrong! :( I put a new o2 sensor in just cause I was working on the car and I also noticed that the battery negative clamp is loose, the bolt thread is stuffed couldn't tighten or undo it. I'll sort it out when I have some more time. Tip for young players: do not try and remove fuel pump with a full tank LOL. I was lucky to have disconnected the fuel line at the filter thinking it could be blocked, after waiting for the line to empty its self of fuel for a minute I noticed it was being gravity fed, as the tank was full and the lines come from almost the bottom of the tank! (sh*t idea) Thanks for your replies guys, I'm slowly learning about this car Edited 28/11/16 01:32 AM by RJF6 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1623178 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 2m 22d Gender: Male Location: SW Sydney Posted 28/11/16 02:12 AM Share Posted 28/11/16 02:12 AM Well sh*t. On Saturday I was itching to write "sounds to me exactly like when e85 chewed the end of my stock pump-to-module hose causing it to come off (multiple times) and stopped my ute dead in its tracks" but didn't due to the comments about 'feeling' fuel flow Lost: 1x opportunity to look like skilled diagnostician glad you got it sorted anyway mate 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92702-f6-not-running/page/2/#findComment-1623189 Share on other sites More sharing options...
