  • Puff
  • Member For: 10y 3m 5d
Ok @skidxr6t I don't know the ford pcm inside and out BUT I can tell you that in my past experience there is a map in some ecu's that observes how fast the throttle is pressed.
It will add more fuel the faster it gets planted providing you tune it that way.
Also there is a map or setting that will add timing similarly.
Basically when you floor it quickly the car should be tuned to react quicker and less efficiently than when you just roll on the throttle.
  • Dropping a turd
  • Member For: 17y 6m 8d
When I posted the  turbo's are stock that isn't exactly a good description.   Both are the standard factory turbo that comes with a BA BF F6 but of course each has been modified in several ways.  The  BF turbo has been modified by nizpro and has a major influence on the power delivery and boost level at given RPM.
This cannot be achieved by tuning alone.  SO tuning alone isn't always the answer to control boost and grip.
More than one one way to skin a cat.
Edited by arronm
  • Puff
Expand
Bollocks.
With the advancement of tuning hardware everything can be controlled via computer.
Using a larger or modified rear housing to control traction and boost delivery is just stupid when the same outcome is available at the press of a button via several different tuning methods.
It is merely a by product and an undesirable one at that to have a car take longer to spool otherwise we'd all have gtx55's on board.
Anyway what exactly was the point of this thread?
:bs:
  • Dropping a turd
Tuning ( broad description ) isn't just about changing paremeters with a laptop . It includes all the bolt ons and how they all work together to complete a package.
Ever heard of turbo / turbine backpressure.
Edited by arronm
  • Puff
Back pressure? Isn't that when some asian chick walks up your back to crack it?
  • Puff
  On 23/11/2016 at 9:43 AM, skidxr6t said:
I find if I slam the throttle quickly I get a sh1tload of power all of a sudden, but if I roll it on to full throttle slowly it isn't the same. edit: what I meant to ask about this is basically if this is something that can be tuned? the speed at which the throttle is pressed meaning the faster it's pressed the more crazy the car becomes.
I also tend not to launch my car, its something that has always ended up in wheelspin :( anyway I can't pass judgment on my cars tune because of the wastegate issue but I must say, it is very nice for cruising around town with a casual tutututututu from normal acceleration every so often lol!
Expand
Expand
Have a look on page 42. It's called tps rate of change. This particular part of the haltech is used for fuel tuning.
I've spent a lot of time tuning this part of the ecu to get perfect throttle manners and engine characteristics whether ice cold or at operating temp. Lol the missus and neighbours must have loved me cos to tune this part you basically sit there and stab the throttle a few hundred times while watching your afr's.
