traffic Member 51 Member For: 9y 9m 16d Gender: Male Posted 05/01/17 10:03 PM Author Share Posted 05/01/17 10:03 PM Just about to get a set of coils. I assume the genuine Ford ones would be the best? But just looking at these genuine ones on ebay: http://www.ebay.com.au/itm/Genuine-Ford-BF-Falcon-Ignition-Coils-Set-Of-6-All-4-0L-Engines-XR6-XT-RTV-F6-/151949507235 and the listing says "NOT RECOMMENDED FOR MODIFIED TURBO'S RUNNING HIGHER THAN FACTORY BOOST" - is this true? Is there a different brand that are better? I'm running 14psi. Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627525 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 3d Posted 05/01/17 10:46 PM Share Posted 05/01/17 10:46 PM Totally wrong, Just go to a local ford and get them there, they are $38 each or $230 for 6, then get new plugs from repco or supercheap and do both at the same time. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627528 Share on other sites More sharing options...
traffic Member 51 Member For: 9y 9m 16d Gender: Male Posted 05/01/17 11:15 PM Author Share Posted 05/01/17 11:15 PM Sweet thanks for the reply. Replaced the plugs last weekend hoping that would do it, I'll go with the genuine Ford coils. Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627531 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 29d Gender: Male Location: Perth Posted 06/01/17 12:24 AM Share Posted 06/01/17 12:24 AM What plugs did you use? Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627545 Share on other sites More sharing options...
traffic Member 51 Member For: 9y 9m 16d Gender: Male Posted 06/01/17 12:30 AM Author Share Posted 06/01/17 12:30 AM I replaced them with the same ones that were in it. NGK Iridium Spark Plugs BKR6EIX-P. Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627550 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 3d Posted 06/01/17 12:49 AM Share Posted 06/01/17 12:49 AM Well done, Did u check the gapping and gep to .7 or leave at .6? This could also cause a slight miss but highly doubtful when new. Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627556 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 29d Gender: Male Location: Perth Posted 06/01/17 01:04 AM Share Posted 06/01/17 01:04 AM That plug is gapped @ .8mm out of the box Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627561 Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 9y 3d Posted 06/01/17 01:24 AM Share Posted 06/01/17 01:24 AM Ahhh I thought it was at .6 for some reason. Should he not gap it to .7? Or not a big issue in your opinion luke? Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627563 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 29d Gender: Male Location: Perth Posted 06/01/17 01:26 AM Share Posted 06/01/17 01:26 AM 6 in the label is the heat range. Depends on boost level but .8 should be fine in this case. Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627564 Share on other sites More sharing options...
traffic Member 51 Member For: 9y 9m 16d Gender: Male Posted 06/01/17 01:27 AM Author Share Posted 06/01/17 01:27 AM I didn't check the plugs, just installed them as they are stock. Link to comment https://www.fordxr6turbo.com/forum/topic/92683-bfmk2-issue-just-started-full-boost-loses-power-and-sounds-kind-of-like-rev-limit/page/2/#findComment-1627565 Share on other sites More sharing options...
