traffic Member 51 Member For: 9y 7m 25d Gender: Male Posted 05/01/17 10:03 PM Author Share Posted 05/01/17 10:03 PM Just about to get a set of coils. I assume the genuine Ford ones would be the best? But just looking at these genuine ones on ebay: http://www.ebay.com.au/itm/Genuine-Ford-BF-Falcon-Ignition-Coils-Set-Of-6-All-4-0L-Engines-XR6-XT-RTV-F6-/151949507235 and the listing says "NOT RECOMMENDED FOR MODIFIED TURBO'S RUNNING HIGHER THAN FACTORY BOOST" - is this true? Is there a different brand that are better? I'm running 14psi. Cheers. Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 10m 12d Posted 05/01/17 10:46 PM Share Posted 05/01/17 10:46 PM Totally wrong, Just go to a local ford and get them there, they are $38 each or $230 for 6, then get new plugs from repco or supercheap and do both at the same time. 1 Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 9y 7m 25d Gender: Male Posted 05/01/17 11:15 PM Author Share Posted 05/01/17 11:15 PM Sweet thanks for the reply. Replaced the plugs last weekend hoping that would do it, I'll go with the genuine Ford coils. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 7d Gender: Male Location: Perth Posted 06/01/17 12:24 AM Share Posted 06/01/17 12:24 AM What plugs did you use? Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 9y 7m 25d Gender: Male Posted 06/01/17 12:30 AM Author Share Posted 06/01/17 12:30 AM I replaced them with the same ones that were in it. NGK Iridium Spark Plugs BKR6EIX-P. Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 10m 12d Posted 06/01/17 12:49 AM Share Posted 06/01/17 12:49 AM Well done, Did u check the gapping and gep to .7 or leave at .6? This could also cause a slight miss but highly doubtful when new. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 7d Gender: Male Location: Perth Posted 06/01/17 01:04 AM Share Posted 06/01/17 01:04 AM That plug is gapped @ .8mm out of the box Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 10m 12d Posted 06/01/17 01:24 AM Share Posted 06/01/17 01:24 AM Ahhh I thought it was at .6 for some reason. Should he not gap it to .7? Or not a big issue in your opinion luke? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 7d Gender: Male Location: Perth Posted 06/01/17 01:26 AM Share Posted 06/01/17 01:26 AM 6 in the label is the heat range. Depends on boost level but .8 should be fine in this case. Link to comment Share on other sites More sharing options...
traffic Member 51 Member For: 9y 7m 25d Gender: Male Posted 06/01/17 01:27 AM Author Share Posted 06/01/17 01:27 AM I didn't check the plugs, just installed them as they are stock. Link to comment Share on other sites More sharing options...
