  • Member For: 8y 9m 24d
I would like to know which oil is best for FG XR6T, I've been recommended Mobile 1 0w40 or 5w50, castrol 0w40 as well. How many literes of oil does an FG take. Thanks
I'm dyslexic and cannot turn off simple functions in tapatalk
  • Dropping a turd
  • Member For: 17y 7m 4d
All you suggesteded will be sweet. Allow 7 litres
Or Castrol 5/40
Edited by arronm
Or Castrol 5/40
What do you think of Penrite 5w40, as good as the others?
  • 1 month later...
  • To Loud
  • Member For: 13y 6m
I know this is an older thread, but this got me thinking. I normally only put in 6.8L of oil when doing the service.
I also check the dip stick to make sure that I don't over fill either.
Is there a recommended value in the manual?
I use Castrol edge 0w40 to make sure it is the same stuff that the tuna uses....
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 21d
  • To Loud
no I am not arguing which oil to use. I chose to use the same oil as what the tuna does.
What I am trying to find out is how much oil is meant to be put in.
I thought it was 6.8L. if it is meant to be 6.0L then I have been over filling mine ffs.
  • Site Developer
owners manual ¯\_(ツ)_/¯
edit: my owners manual for my BA (2004) says 6.6L wet fill (no filter), 7.0L dry fill (including filter)
I've always put in 6L and it always ends up right on the "full" mark.
Edited by k31th
  • Member For: 17y 6m 6d
Check the manual as I hear FG sumps are different, but I don't think the volume changes much if any.
