ROB83R Member 1,632 Member For: 8y 7m 22d Gender: Not Telling Location: Radioactive wasteland Posted 19/11/16 01:16 AM Share Posted 19/11/16 01:16 AM (edited) There's vids in @JETURBO tuning thread of what cars behave like on the street with that kind of power. I'm all for it. Fun daily in my opinion. Definitely wouldn't let ya nanna drive it but. Edited 19/11/16 01:16 AM by ROB83R Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 13d Gender: Not Telling Posted 19/11/16 01:21 AM Share Posted 19/11/16 01:21 AM I reckon sub 400rwkw is an ideal power level for street, fun and not breaking too many things. how do you propose to get the power down onto the road? what rear tyres would you be using? what's the widest that fits on rear of fg sedan? 285? Link to comment Share on other sites More sharing options...
[THOMMO] Member 94 Member For: 8y 6m 24d Posted 19/11/16 01:26 AM Author Share Posted 19/11/16 01:26 AM mainly luck I'd say. 10inch rear 285 semi slicks, had nitto NT05 previously but may look at others Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 14d Gender: Male Location: Perth Posted 19/11/16 03:43 AM Share Posted 19/11/16 03:43 AM If you know how to drive you can never have to much power...... Same as a bike . Hello 250kph 6th gear wheel stands............ Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 7m 16d Gender: Male Location: Central Queensland Posted 19/11/16 05:23 AM Share Posted 19/11/16 05:23 AM I'm with Aaron. You can never have to much power. Many will argue the fact that is worthless if you can't get out to the ground. Like anything with big torque, it's all about throttle modulation. Nothing wrong with 160 km/h power skids..... 3 Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 7m 16d Gender: Male Location: Central Queensland Posted 19/11/16 05:29 AM Share Posted 19/11/16 05:29 AM 4 hours ago, gaz097 said: You will get it to hook up. And yes when it does it feels amazeballs. I recon 27-30psi Gtx42 would be about ideal/ starting to get to much in a falcon. Garretts really like 35-40 psi. That's where they're most efficient. With very limited tuning, my 4202 is seeing positive pressure at 2200rpm. I never wanted hp records, but built the car to be powerful, yet have good street manners and drivability. That's where the 42 excels.... 1 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 1m 16d Gender: Male Location: Perth Posted 20/11/16 03:10 AM Share Posted 20/11/16 03:10 AM I'm with Aaron. You can never have to much power. Many will argue the fact that is worthless if you can't get out to the ground. Like anything with big torque, it's all about throttle modulation. Nothing wrong with 160 km/h power skids.....Unless you have live rear axle & non lsd ... then it's just skidcity Link to comment Share on other sites More sharing options...
Ezy2Confuze Member 898 Member For: 15y 2m 26d Gender: Male Location: West Perth. Posted 20/11/16 04:36 AM Share Posted 20/11/16 04:36 AM I've read a lot of the 400kw+ & 500kw+ forums & in my case seeing comments from a lot of people on the forums the sweet spot for me will be around 370kw on 98 & low to mid 400's on e85.I chose those targets because I've seen plenty of members get into the 300's in their first molding session but give it a year or 2, get used to the power & want more.Me, I intend to do two lots of major mods, followed by the reliability mods.That means valve springs, oil.pump gears & probably the end plate. Depending on my luck maybe the harmonic balancer as the tuner has seen a few of those have issues. Then it's intercooler, Process West fuel surge with pump, turbo back exhaust & GTX3576r (gen2's cores are out now) with two tunes for 98 & e85, I'm also thinking of going the growler intake, mainly because I want to keep excess noise from the front & unwanted attention yet still have half decent airflow. I'll be having the turbo housing checked next service plus the manifold bolts checked & tightened if needed, plus the fuel pump checked, so I have an idea if I need to budget more for anything else needing replacement.The only things I'm not sure of doing are better exhaust manifold & a better intake plenum, from what I understand they can help lower stresses on the engine etc. which for me is a good thing. 1 Link to comment Share on other sites More sharing options...
[THOMMO] Member 94 Member For: 8y 6m 24d Posted 20/11/16 05:13 AM Author Share Posted 20/11/16 05:13 AM Is that on an FG? Ill be getting rid of my growler intake at some stage Link to comment Share on other sites More sharing options...
Ezy2Confuze Member 898 Member For: 15y 2m 26d Gender: Male Location: West Perth. Posted 20/11/16 06:41 AM Share Posted 20/11/16 06:41 AM Yeah it is, already have a growler with big mouth from when they had the special on their site.I forgot to add in timing chain & guides with the vavle springs. The car us just under 99,000 so I might as well do them all in one hit & save on two lots of labour Link to comment Share on other sites More sharing options...
