Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 22d Gender: Not Telling Posted 17/12/16 04:11 PM Share Posted 17/12/16 04:11 PM Not directed at you Ralph, just furthering the train of thought... Also block to flywheel clearance, input spline engagement, spigot bush placement/length, ring gear engagement to starter (mentioned), clutch adjustment (mentioned), rear main seal to flywheel clearance (it looked pretty close in the picture), bolt hole depth after machining, bolt length. Basically everything that comes into contact or near to the flywheel should be measured and checked. Most of that should be fine but all should be checked. 1mm might not matter but 5 mm would likely be a different story. It has to be checked. Did I mention that stuff should be checked? Would you really want to use a spacer that produces possibly different expansion rates than the flywheel and crank and in turn changes bolt tension and stresses the bolts and dowells more than the already problematic setup? Adding another element that can slip and wear itself and other parts is far from ideal even if dowelled. Is manufacturing a billet custom hardened spacer (to allow for somewhat even thermal expansion of said spacer) worth the cost of just replacing the crank? Would anyone reading this be happy to leave their car at a shop and pay for or allow this kind of fix? Not me, no thanks. If I had to be dodgy I would just remove any runout then partially tig the bolts to the flywheel once they were torqued up but I'd prefer to do it right the first time....oh wait..... Who knows maybe it will all just stick this time with just being put together as its?! Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1625627 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 2d Gender: Not Telling Location: Radioactive wasteland Posted 17/12/16 08:45 PM Share Posted 17/12/16 08:45 PM I think what puff is saying is do it right the first time. Someone should've told fraud that. I'm all for the roadkill garage fix. Rock it with 900hp is the only true test. Then when it goes again in spectacular style replace the crank. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1625629 Share on other sites More sharing options...
Ale Member 249 Member For: 13y 8m 26d Posted 18/12/16 03:44 AM Share Posted 18/12/16 03:44 AM Im all for "giving it a shot", but messing with 1000rwhp and loose flywheels is crazy town... you boys seen what happens when flywheels or clutches explode or come flying out of bell housings!! Many a person now limps for the rest of their lives due to such failures. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1625647 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 2d Gender: Not Telling Location: Radioactive wasteland Posted 18/12/16 04:35 AM Share Posted 18/12/16 04:35 AM (edited) Buzzsaw I think over a certain horsepower level or time slip you're supposed to have a blanket on the bellhousing to stop that. These just tear up anyway. And are just for autos with transbrake on andra tracks. You could do this or pull the crank and fit a new one. Edited 18/12/16 04:37 AM by ROB83R Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1625650 Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 16y 13d Gender: Male Location: Brisbane Posted 21/12/16 02:14 PM Author Share Posted 21/12/16 02:14 PM Been back on the road for a few days now, put around 300km on it so far with no obvious issues so far. I still plan on pulling the gearbox out in a few weeks and check to make sure everything has stayed tight, but so far so good 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1625993 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 22d Gender: Not Telling Posted 21/12/16 02:43 PM Share Posted 21/12/16 02:43 PM Good news. Let's hope it stays tight! Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1625996 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 24d Gender: Male Location: Perth Posted 22/12/16 02:07 PM Share Posted 22/12/16 02:07 PM Checked harmonic balancer???? Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1626063 Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 16y 13d Gender: Male Location: Brisbane Posted 22/12/16 02:29 PM Author Share Posted 22/12/16 02:29 PM Yep it is all good, nothing has come loose and there are no vibrations that I can feel, even up neat 7000rpm. I put plenty of miles on it today, so it is up near 550km since it has been back together. Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1626064 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 22d Gender: Not Telling Posted 22/12/16 02:55 PM Share Posted 22/12/16 02:55 PM 550km is nothing. Anything will last that long unless it had been assembled by a sandpit. If you can feel the vibration, in this case, it's already too late. Just keep your ears/feet/etc listening mate and you should be ok. Pull it apart again at 5 thousand and see what's up. Hoping for the best homie. Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1626065 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 24d Gender: Male Location: Perth Posted 22/12/16 02:58 PM Share Posted 22/12/16 02:58 PM Hope it hangs together for you. Time will tell... Check my balancer, came a bit more than loose..... 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92641-not-qik-fg-xr6t-manual-ute/page/9/#findComment-1626066 Share on other sites More sharing options...
