NOT QIK - FG XR6T Manual Ute
samhouston
  • Member For: 15y 8m 27d
Hi all,
I wanted to make a build thread so here goes....
I have had this ute since February 2011, bought it second hand with 21,000kms on it and drove it as a standard ute for a while.
I did a few small things to it, put some springs in it and changed the intake, nothing major at all.
Then decided at some point that it wasn't enough, so added a few bolt on goodies...
This consisted of;
  • GTX35 with external gate
  • ID725 injectors
  • PW Surge Tank with 044
  • PW Stage 2 IC
  • NPC Heavy Duty Clutch
  • Atomic Valve Springs
This was good enough to make 507kW at the wheels, and run an 11.75 @ 119mph with a 1.62 60ft.
I should have probably been pretty happy with that in a fairly middle modified manual ute...
But then for some reason, on the 18th October 2012, I decided to pull the engine out to make some more power.
So four long years later and the engine is complete and in the car, the car is yet to be tuned but the aim will be somewhere between 850-900hp (630-670kW)
The list of modifications has grown, my bank account has shrunk but I am sure it will all be worth it when I get to drive it.
Engine built by Colin Lloyd @ Headsense
Mahle Pistons
Manley Rods
Atomic billet oil pump
Atomic 16mm main cap girdle
Atomic 14.3mm head stud kit
Atomic Ovate valve springs
Custom Cam grinds
Atomic Vernier camshaft sprockets
Cylinder head ported and flowed
Crankshaft balanced and heat treated
Garrett GT4294
6boost manifold
Custom 4inch dump & exhaust
Turbosmart 50mm wastegate
Turbosmart 50mm race port BOV
Turbosmart eBoost 2
PW Stage 2 intercooler with custom piping
PW surge tank with twin Walbro 460s
PW dual entry fuel rail
Turbosmart Fuel Regulator
Bosch 2200cc injectors
Custom power steering reservoir relocation
Xtreme twin ceramic clutch
The ute also now sports Brembos & a set of Pedders XA coil overs in the front corners.
The tuning will be done by Clint @ Profile, I will check back here once it is all done and update.
  • Like 4
2 hours ago, MBAF said:
Mint!
Whens the tune? We want results :D
It will go on the rollers this coming Wednesday/Thursday and then I need to give it a bit of a run in before we give it a final tune.
  • Member For: 10y 11m 24d
One tough ride!
12 hours ago, samhouston said:
This consisted of;
  • ID725 injectors
  • PW Stage 2 IC
I can't compute ID725's and 119mph and equal 507rwkw, maybe 407..?
Or maybe I don't know sh*t, always possible. Any case, love ya work.
501rwkw @16psi today
I will put a few kilometers on the engine and then back for a massage and some more boost.
Have a few little things to iron out with the exhaust location and an issue with a very long brake pedal but I'll get that sorted.
Very happy with the progress so far
  • Like 5
