Tcarver New Member 3 Member For: 8y 3m 8d Posted 09/11/16 02:43 AM Share Posted 09/11/16 02:43 AM Hi guys I have a BF XR6T that has done 230000km and the transmission is not operating correctly. When it is cold it will try to go into reverse and drive then I get the ABS, Park brake and Traction control lights flashing on the dash then speedo stops working also. When this is at its worst it will also throw the check engine light up. This is sorted by turning ignition off then back on which seems to get rid of lights and speedo works again. This is an intermitant problem and once this clears everything runs fine. We have tried a service which included a new trans pan and filter and filled with the ZF fluid from FORD which has made it better but still not 100%. ANY SUGGESTIONS PLEASE Link to comment Share on other sites More sharing options...
boegey Member 123 Member For: 10y 11m 9d Posted 09/11/16 03:01 AM Share Posted 09/11/16 03:01 AM Might be dodgy coils I know when they start to go it can reak all kinds of havoc and speedo cutting out is a classic symptom 2 Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 12d Gender: Not Telling Posted 09/11/16 03:17 AM Share Posted 09/11/16 03:17 AM (edited) After checking coils as mentioned above (check them for cracks). Battery terminals should be checked too. For me it was only doing it when I booted it but it started happening more often and with less acceleration. I had condemned the box too - I would boot it and revs would spike to 5-6k like the thing had engaged neutral...then ABS/TC/handbrake light would flash and speedo drop out. Edited 09/11/16 03:18 AM by skidxr6t 1 Link to comment Share on other sites More sharing options...
boegey Member 123 Member For: 10y 11m 9d Posted 09/11/16 06:40 AM Share Posted 09/11/16 06:40 AM You need to be careful if the coils are going and they get to the point where they are cutting out for a millisecond the zf will automatically go into neutral because it thinks the cars been turned off and then when it refires it slams it back into gear and will break input shafts 1 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 9m 14d Posted 09/11/16 08:30 AM Share Posted 09/11/16 08:30 AM How I check coils is to take the rubber boot off & look in where the coil spring goes , if you see grey / white dust (even the slightest bit ) in the hole then you KNOW the coil is RS . They hate water so if you see corrosion in the plug hole & on coil boot give them a new home in the bin (if you have to wash motor & don't want to remove cover to get water out then just buy new coils the next day ) The coils in this reguard are fragile & don't expect them to last the life of the vehicle. Only buy genuine ford ,they are the best quality you can get - buy cheap aftermarket & expect to change them soon. You can buy them cheaper on fleabay. 1 Link to comment Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 5m 4d Gender: Male Location: Melbourne Posted 09/11/16 09:19 AM Share Posted 09/11/16 09:19 AM Do you have an edit or tune in your car? If you do - maybe flash back to stock to see if it also behaves the same way? Link to comment Share on other sites More sharing options...
Tcarver New Member 3 Member For: 8y 3m 8d Posted 25/11/16 01:11 AM Author Share Posted 25/11/16 01:11 AM Thanks Guys would never have looked at coils. I have a set coming and will let you all know how I go. Link to comment Share on other sites More sharing options...
Tcarver New Member 3 Member For: 8y 3m 8d Posted 28/11/16 01:39 AM Author Share Posted 28/11/16 01:39 AM Thanks for your feedback, saved me an absolute fortune in wasted dollars. Replaced coils and she is running like a dream. VERY HAPPY MEMBER 3 Link to comment Share on other sites More sharing options...
RiceSnail New Member 1 Member For: 8y 1m 12d Posted 29/11/16 09:40 PM Share Posted 29/11/16 09:40 PM I had similar problem. I changed the battery and was all good Link to comment Share on other sites More sharing options...
