Tein Coilover Help
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m 2d
EDFC just moves the same controller, but electronically instead of physically (manually with your hands). The firmness/rebound of the shocks is modified either electronically or physically. The ride height can only be adjusted via the nuts on the shock absorber itself.
  • Member For: 12y 5m 14d
Ah, awesome! Thanks for the clarification Keith :) If I raise the car a bit, that should lighten up the steering a little too shouldn't it? It's quite firm at the moment.
  • Dropping a turd
  • Member For: 17y 4m 13d
You adjust the threaded collars. Its just like a dirt bike rear shock. You dont change the spring rate only the preload. the dampening is adjusted with the clickers. We have ours set on the softest for the street as we have the race series.
If you change ride height you will need a wheel align after.
Edited by arronm
  • WOT?
  • Moderating Team
  • Member For: 12y 14d
Make sure that once you set the height you get a decent front and rear alignment. (not all shops are equal)
Then play with the dampening.
I've just found out yesterday that the controller at least turns out. All the buttons light up, but all 3 presents are 'red' and not 'green', and on the display it says 'F-EA and R 00'. Anyone got any idea what this means? I would imagine the F is front and normally would be numbers and the R is rear and the same.
