jas98 Member 1,050 Member For: 12y 11m 13d Gender: Male Location: Maryborough Qld Posted 01/11/16 08:21 PM Share Posted 01/11/16 08:21 PM . so im replaceing fuel pump in a spare moduel I have. for a xr6t ba sedan. anyway whats the best way to install the factory style corrugated hose. I have a new one for for pump and a new for retutn ..the return one is on but I can pull it off with force so will just clamp that as it wont be under much pressure. but the one for the actual pump id like to do correctly I did the return one first and I tried boiling water but it did not work so tried a heat gun and it worked... but slightly loose. hence why ill put a clamp on it. do I dobthe same for fuel pump hose? Link to comment https://www.fordxr6turbo.com/forum/topic/92612-fuel-pump-corrugated-hose/ Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 11m 15d Posted 02/11/16 06:16 AM Share Posted 02/11/16 06:16 AM Need sumergable fuel hose, and yes clamp it. Link to comment https://www.fordxr6turbo.com/forum/topic/92612-fuel-pump-corrugated-hose/#findComment-1619354 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 17d Gender: Not Telling Location: Radioactive wasteland Posted 02/11/16 06:20 AM Share Posted 02/11/16 06:20 AM see the hose at the end. Don't do it like that apparently. Link to comment https://www.fordxr6turbo.com/forum/topic/92612-fuel-pump-corrugated-hose/#findComment-1619357 Share on other sites More sharing options...
jas98 Member 1,050 Member For: 12y 11m 13d Gender: Male Location: Maryborough Qld Posted 02/11/16 07:17 AM Author Share Posted 02/11/16 07:17 AM thanks. however I already brought the propper hose like this: http://m.ebay.com.au/itm/262635495531 its the factory stuff Link to comment https://www.fordxr6turbo.com/forum/topic/92612-fuel-pump-corrugated-hose/#findComment-1619367 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 11m 15d Posted 02/11/16 08:41 AM Share Posted 02/11/16 08:41 AM Ahh see. You actually explained it really well I just didn't read it. I didn't actually know you could buy it. Your on the right track with heat, but seams risky, considering what you have done so far. And you don't want to add lubricant. Maybe a smear of petrol would help to get it to slide. How close does it go on with boiling water? Also email them. The add seemed helpful Link to comment https://www.fordxr6turbo.com/forum/topic/92612-fuel-pump-corrugated-hose/#findComment-1619387 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 3m 9d Posted 04/11/16 09:27 AM Share Posted 04/11/16 09:27 AM I;m interested in how this is done I tried it with hot water - didn't work ,tried a heat gun this would of worked but I got it too hot & melted the pipe. Ended up submersable hose & hose clamps - been on for nearly 3 years & no problems but I would prefer the plastic hose (maybe should have bought the module from fleabay already assembled) Link to comment https://www.fordxr6turbo.com/forum/topic/92612-fuel-pump-corrugated-hose/#findComment-1619782 Share on other sites More sharing options...
