Mufasta Member 4 Member For: 11y 3m 7d Posted 17/02/17 01:41 AM Share Posted 17/02/17 01:41 AM thanks for that mate. I didnt know you could tag people haha. On 05/02/2017 at 12:33 PM, Puffwagon said: Whether or not it has been solved or is this issue in this instance, I'll chuck in 2c worth of info. Injector drivers in the pcm can fail. Expand Thanks Puffwagon. Ive found another Thread which seems to match the same symptoms that I have. Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/page/2/#findComment-1632060 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 5m 2d Gender: Male Location: WA, Perth Posted 17/02/17 04:25 AM Share Posted 17/02/17 04:25 AM All good mate. now you know. Another tip for you. you didn't have to reply to two separate posts. you can actually click on the plus sign next to the quote button which allows you to reply to multi quotes in one post. I hope that makes sense. Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/page/2/#findComment-1632080 Share on other sites More sharing options...
sm13f6 Member 34 Member For: 10y 1m 17d Posted 17/02/17 09:24 PM Author Share Posted 17/02/17 09:24 PM hey guys , yep did get to the end of this after buying a new ecu and eveyrthing haha turned out to be a slight intake manifold leak on no1 underneath gasket , the factory ecu is quite smart and it sees the leak and compensates by dropping no6 to balance the engine , replaced the intake manifold gasket and its been good as new haha 2 Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/page/2/#findComment-1632143 Share on other sites More sharing options...
Mufasta Member 4 Member For: 11y 3m 7d Posted 21/02/17 03:38 AM Share Posted 21/02/17 03:38 AM Hi mate. That's great news. ive since discovered a leak on my manifold gasket at cyl no.1 as well. So I will get this changed asap and let you know if mine is the same! Thanks for replying as it was starting to do my head in! Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/page/2/#findComment-1632419 Share on other sites More sharing options...
mattycee New Member 11 Member For: 6y 6m 7d Gender: Male Location: Sydney Posted 25/10/18 08:28 PM Share Posted 25/10/18 08:28 PM On 05/02/2017 at 12:33 PM, Puffwagon said: Whether or not it has been solved or is this issue in this instance, I'll chuck in 2c worth of info. Injector drivers in the pcm can fail. Expand mine has done the same, cylinder 5 misfire, no signal sent to coil. ran vac tests, resistance tests on injector plugs (ID 1000cc injectors and adaptors to suit) threw code P1358 and wouldn't clear. new ecu in and it's at ford being reset now. I just don't want it to happen again. new loom etc too. might install new injector plugs to remove the adaptors. fingers crossed lol Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/page/2/#findComment-1666175 Share on other sites More sharing options...
