  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 1d
  On 11/10/2016 at 12:13 PM, ROB83R said:
All this torque and still no answer....
Expand
It's  a bit like "can you use threaded rod for wheel studs?"
Yeh you could and it might even work, but would you bother ?
  • Member For: 8y 11m 13d
  • Gender: Not Telling
Nah wrong pitch jet.
I know what you mean and my first thought when I opened the thread no pun intended was why cheap out on such a simple but important part.
But @eff xr6t made a valid suggestion backed up with fact.
Edited by ROB83R
  • Dropping a turd
  • Member For: 17y 6m 5d
To determine the best studs to use , you need to understand why they come loose.
  • Member For: 12y 9m 9d
  On 11/10/2016 at 12:10 PM, JETURBO said:
Phuck me lads it's $50 for a full pack of studs,nuts,stainless gaskets,copper washers,oil flange gaskets to do the job properly
what's with you khunts its half a tank of fuel ffs
Expand
where can u get all that for $50?
wss never trying to cheap out. it has sonic stud kit on turbo to manifold at the moment but came loose....also its 1.5 thread pitch both ends on the studs ...could that be why it came loose? it was desighned for it..
  On 11/10/2016 at 10:33 AM, eff xr6t said:
I just use 50mm bolts with the head cut off to create a stud and flange nuts on my car. Tighten them up after the first heat cycle and I've never had them come loose. FACT!!
Expand
was that turbo to manifold or manifold to head or bolth?
  • Dropping a turd
  On 11/10/2016 at 11:17 AM, Ralph Wiggum said:
The two threads are different pitches for a reason.
Expand
Exactly. Take a look at the location of the unthreaded section of the stud.  Guess where that needs to sit.
im pretty certain the thread the same potch on the sonic atuds I got as I just used a 1.5 m10 bolt on both ends to see if it was and it worked..
  • Member For: 22y 1m 2d
Phuck studs, for the manifold to head, I make sure that all the threads on the head are tapped right down to the bottom by running a tap to the bottom.  Then I use allen key headed grade 8 bolts with nordlock washers. I measure for the right size bolt so when tightened up the thread grabs to the bottom of the hole. (I know you are not meant to tighten bolts into ally but it works if plenty of thread)
Yes there are two holes where you need to elongate the hole a little to get the bolt in but no big deal, you can use studs there if you want.
Pretty much the same on the turbo except two bolt holes do need elongation to get the allen key headed bolts in.
I have other ways I secure studs but if I explained it you would call me crazy. The point is a stud and nut on its own will always loosen.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 22d
Expand
I'd love to hear your explanation :spoton:
