  • Puff
  • Member For: 10y 3m 2d
It would make no difference if it was fine thread the whole way up.
It may not be made like that from factory but it makes no difference in a practical application.
Edited by Puffwagon
Clarification
  • Member For: 8y 11m 12d
  • Gender: Not Telling
  On 11/10/2016 at 10:33 AM, eff xr6t said:
I just use 50mm bolts with the head cut off to create a stud and flange nuts on my car. Tighten them up after the first heat cycle and I've never had them come loose. FACT!!
Expand
I like this backyard racer approach. Simple sh*t just works sometimes it's crazy.
  • Puff
Maybe someone should point out the benefits of using a longer coarse thread into cast iron vs using a shorter fine thread into a steel alloy.
Maybe they can also mention why cheaper iron is used in mass production of turbine housings vs more expensive materials and production methods and why cast iron nuts are not feasible.
After all these are the reasons that that the studs are made the way they are.
This would actually add substance to the thread and answer the ops question rather than useless, devalued comments like "Google it" or "there is a reason for it" with no explanation.
Smh.
Edited by Puffwagon
Removed a word
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 1d
Phuck me lads it's $50 for a full pack of studs,nuts,stainless gaskets,copper washers,oil flange gaskets to do the job properly
what's with you khunts its half a tank of fuel ffs
  • Like 4
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 22d
The studs are M10x1.25 on one side and M10x1.5 on the other. The 1.5 end goes into the manifold and the 1.25 allows for a finer thread and more torque on the turbo side.
  • Puff
Nah that was me boys.
Sometimes you need to remind people what the forum is here for.
It's all good :stirthepot:
Brb welding my turbo on to save money on gaskets.
Edited by Puffwagon
Brb
  • Like 2
