MBAF Bronze Donating Members 2,156 Member For: 8y 5m 10d Posted 17/10/16 08:08 AM Share Posted 17/10/16 08:08 AM Someone needs a hug..... 2 Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 9m 7d Posted 17/10/16 08:10 AM Share Posted 17/10/16 08:10 AM Someone needs a hit of boost ffs. 1 Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 5m 10d Posted 17/10/16 08:14 AM Share Posted 17/10/16 08:14 AM (edited) .... Edited 17/10/16 08:18 AM by MBAF 2 Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 9m 7d Posted 17/10/16 08:26 AM Share Posted 17/10/16 08:26 AM Best comment today Link to comment Share on other sites More sharing options...
Ben_BAXR6 Member 49 Member For: 8y 3m 22d Gender: Male Location: Adelaide Posted 17/10/16 08:51 AM Author Share Posted 17/10/16 08:51 AM 34 minutes ago, MBAF said: 2 chan amp will not be good enough for a front/rear set of speakers and you will also lose fading capability and be under driving speakers. Ill have to disagree with you on this one, the 2 channel amp is a nakamichi PA-D1000B, which is 500w @ 4 ohm, 750w @ 2 ohm, and 1000w @ 1 ohm, being a boilermaker my grasp of electronics isn't exactly huge, but I know I can wire it up in a couple of configurations in 2 ohm and 1 ohm, and my speakers being 75w rms each, Ill have enough power for them. I hadn't thought about the fading thing though, don't know how much of a huge effect this will have. Put simply, Im not buying a new amp as of yet, Im already in for a headhunt and A/V Conversion I wasn't looking to buy haha. Im not chasing SQ or SPL, otherwise I would have bought much better speakers etc than the ones I did, and Id be running a bigger sub(s) in the boot with proper boxes etc. Im just chasing something that sounds better than stock, and trying to use as much of the gear I currently have as possible, and I'm aware of the compromises and limitations that has Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 8m 6d Gender: Not Telling Location: Radioactive wasteland Posted 17/10/16 09:09 AM Share Posted 17/10/16 09:09 AM I reckon you're on the right path. 2 Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 5m 10d Posted 17/10/16 09:49 AM Share Posted 17/10/16 09:49 AM 53 minutes ago, Ben_BAXR6 said: Ill have to disagree with you on this one, the 2 channel amp is a nakamichi PA-D1000B, which is 500w @ 4 ohm, 750w @ 2 ohm, and 1000w @ 1 ohm, being a boilermaker my grasp of electronics isn't exactly huge, but I know I can wire it up in a couple of configurations in 2 ohm and 1 ohm, and my speakers being 75w rms each, Ill have enough power for them. I hadn't thought about the fading thing though, don't know how much of a huge effect this will have. Put simply, Im not buying a new amp as of yet, Im already in for a headhunt and A/V Conversion I wasn't looking to buy haha. Im not chasing SQ or SPL, otherwise I would have bought much better speakers etc than the ones I did, and Id be running a bigger sub(s) in the boot with proper boxes etc. Im just chasing something that sounds better than stock, and trying to use as much of the gear I currently have as possible, and I'm aware of the compromises and limitations that has I rest my case....if that's your amp then your setting your self up for hurt and clearly have no clue at all... I mean first thing is its a mono and not even a 2 channel! If you dont even know what that means to your sound setup I suggest you stick with your standard system.... Secondly that amp wont do hpf so you will get no tones through ANY of your speakers unless its 50hz whoch I bet your speakers wont do (because they are mid/high range) Thirdly a single chan amp cant run 2 chan signal little own 4 chan signal. Bridging a chan would be minimally acceptable...... I wont keep going here but goodluck! lol 1 Link to comment Share on other sites More sharing options...
Ben_BAXR6 Member 49 Member For: 8y 3m 22d Gender: Male Location: Adelaide Posted 17/10/16 10:31 AM Author Share Posted 17/10/16 10:31 AM No need to be an ass. I simply thought 2 x sets of RCA's were outputs, not 1 x input and 1 x output. I didn't buy the amp, it came in the car already installed. I apologise for not being an expert. No big deal, I guess my hand is forced and ill have to fork out for an amp while I'm at it. Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 8m 6d Gender: Not Telling Location: Radioactive wasteland Posted 17/10/16 10:43 AM Share Posted 17/10/16 10:43 AM Don't worry about Damo he's a very experienced person #fighterpilotlyf Amps are cheap don't stress. Get a 4x50w amp and a H/U with 4 or more rca outs. Winning! 1 Link to comment Share on other sites More sharing options...
Ben_BAXR6 Member 49 Member For: 8y 3m 22d Gender: Male Location: Adelaide Posted 17/10/16 10:58 AM Author Share Posted 17/10/16 10:58 AM True, they aren't too expensive, was just hoping to dodge a bullet. Link to comment Share on other sites More sharing options...
