bad inferno Member 130 Member For: 19y 10m 4d Posted 19/11/16 10:10 AM Author Share Posted 19/11/16 10:10 AM (edited) Did the rear brakes today... Took longer than I thought as I had trouble setting the handbrake. My adjuster on both sides were screwed all the way "in" and had jammed so I had to adjust it a few mm out once I freed it up. ended up taking it out and used some multigrips & pliers. FYI Rear brakes have HEAPs of clearance to the GT335 rim although I have the 9" staggered rears. So want to do the front brakes and before I take it apart was wondering if anybody knows how to tell the left & right brake hose apart. I suppose it will make sense when I take the wheel off and have a look however want to do whatever I can before I start. Any idea on left & right ?. there is obviously no reference to the part No on line. FG Front brake lines for PBR M-Series Edited 19/11/16 10:12 AM by bad inferno Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1621882 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 1m 18d Gender: Male Location: Western Sydney Posted 19/11/16 10:33 AM Share Posted 19/11/16 10:33 AM Same same but opposite you'd assume. You'll figure it out once you hold them next to the factory lines. Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1621883 Share on other sites More sharing options...
bad inferno Member 130 Member For: 19y 10m 4d Posted 24/11/16 12:26 PM Author Share Posted 24/11/16 12:26 PM Getting my front bushes replaced next week as I have really bad inside tire wear, So decided I will have to wait another week before the new calipers go onto the front. Dont trust the guys doing the bushes with the new calipers -although Im sounding paranoid now and there not even on ! Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1622627 Share on other sites More sharing options...
bad inferno Member 130 Member For: 19y 10m 4d Posted 03/12/16 10:33 AM Author Share Posted 03/12/16 10:33 AM (edited) Finally on, had the rears on for the last few weeks and the fronts went on today after I got the front end bushes done this week. there's only a few mm clearance on the GT335 front wheels on the spokes closest to the hub Edited 03/12/16 10:35 AM by bad inferno 5 Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624120 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 3m 25d Gender: Male Location: Frankston, 3199 Posted 03/12/16 10:36 AM Share Posted 03/12/16 10:36 AM Fark'n awesome Do you need to rotate pads now when you rotate wheels? Lovely bit of kit Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624123 Share on other sites More sharing options...
bad inferno Member 130 Member For: 19y 10m 4d Posted 03/12/16 10:42 AM Author Share Posted 03/12/16 10:42 AM The only thing Im not happy about is my old DBA T3 rotors never showed any sign of rust where as these discs are showing a very fine rust ring closest to the hub (where the pads don't contact). Im going to be really pissed if they get progressively worse and have a rust ring where the disc joins the hub. It does simply wipe off now however dont wont to be doing that... Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624125 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 3m 25d Gender: Male Location: Frankston, 3199 Posted 03/12/16 10:44 AM Share Posted 03/12/16 10:44 AM Bit of Inox (like WD-40, but lanolin based) Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624129 Share on other sites More sharing options...
bad inferno Member 130 Member For: 19y 10m 4d Posted 03/12/16 11:36 PM Author Share Posted 03/12/16 11:36 PM Thanks Rab, Ill find some Inox, never heard of the stuff before however in reading looks a good Aus. product. Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624205 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 3m 25d Gender: Male Location: Frankston, 3199 Posted 04/12/16 08:00 AM Share Posted 04/12/16 08:00 AM Hold off on that idea until someone else chimes in. Wasn't thinking properly last night - I'm not sure what effect it may have on the pads. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624241 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 27d Gender: Male Location: Perth Posted 04/12/16 08:38 AM Share Posted 04/12/16 08:38 AM Yeah, best not lubricant your brakes. 4 Link to comment https://www.fordxr6turbo.com/forum/topic/92502-took-the-plunge-m-series/page/2/#findComment-1624243 Share on other sites More sharing options...
