Another FG N/A to Turbo Conversion
utelife
  • Member For: 11y 2m 7d
Interesting philosophy and actually has merit. If you intend to use after market manifolds, turbo etc why not...30 thou ks of bulk skids is alot of abuse. Would last more than long enough to build a good engine if driven somewhat kindly..
Also what the guys do with the sohc engines and even stock engines from other brands like the jz's etc. We probably do get a bit precious about it all.... it will work mate go for it
sh*t nobody has actually answered the questions about the vacum lines have they?... I will take pics of the routing of it helps...
  • Bronze Donating Members
  • Member For: 8y 5m 12d
^ this.
They were pushing the n/a motor hard. We were doing roll ons the highway and power skids every 2nd day in that car. Was an animal.
Like I said keep it 300-400kw max and you will be fine.
  • Like 2
Brake booster big one, smaller one fuel pressure reg and bov.
pcv vacuum and the T goes to... this think it has to do with the brakes??
will need to change this NA uses a different type, pcv valve.
bov and pcv breather.
You will also need boost solenoid and maybe need to add the wiring to the harness??
turbo oil feed
and drain to sump, might have to tap sump?
Cant think of anything else you have missed right now that's all I got...sorry bout potato pics
lol was hoping nobody would call that out tocchi... should see the timing cover...and the earls oil filter fkn leaks a bit despite all attempts to stop it. I just keep putting oil in it hey its like...a rolling oil change. Always somewhat fresh.....
  • Like 2
  • Sandtrap Motorsport
  • Member For: 16y 2m 2d
Rust prevention. ;)
I had to change mine a couple of months ago, $30 and 10 mins of work. No more leaks. Good result haha
  • 2 months later...
  • Member For: 9y 3m 19d
Hows the build going mate? Any updates?
I put a turbo on my bf n/a and its made 242rwkw on 8psi and lasted nearly 2 1/2 years before I pulled it out and it was still going strong with no issues. Just don't push it too hard :)
