  • MattyP
  • Cruise Control
  • Member For: 13y 1m 25d
I'm pretty stuck with nulon atm
comes in a 6l bottle, on special regularly and is e85 ok
might go back to diesel oil though
  • 2 years later...
  • Member For: 7y 2m 17d
So I have a 5 litre bottle of the 10 tenths 15w 50 and happen to have a couple of litres of some fully synthetic 10w 50.  Can I mix them and what are the  consequences of this.
Cheers
Edited by nzti325
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 20d
from a cursory google search copypasta:
  Quote
All mineral oils are produced from the same basic petroleum feedstocks. Different oil viscosities will not separate or react negatively to each other because the base oil is molecularly the same. It's the different oil additive systems between brands that shouldn't be mixed - if you're concerned about the oil performing exactly how it was designed.
Oil additives include:
Anti-oxidants to prevent thickening at high operating temperatures.
Pour point depressants which lower the temperature of wax coagulation
alkaline materials to neutralize acids formed during combustion.
Rust and corrosion inhibitors.
Detergents to reduce sludge and varnish.
Dispersant additives to hold contaminants in suspension.
Extreme pressure additives to prevent metal to metal contact under high loads.
Viscosity index improvers in formulating muilt-grade (viscosity) oils.
The exact type and amount of these additives varies between brands and when mixed may not function as efficiently as desired. Different viscosities of the same brand oil will have different amounts of viscosity index improvers (polymers), but otherwise the additive systems will be the same.
"The exact type and amount of these additives varies between brands and when mixed may not function as efficiently as desired. Different viscosities of the same brand oil will have different amounts of viscosity index improvers (polymers), but otherwise the additive systems will be the same.
From the Chevron .com site:
"Can I mix different viscosity grades of motor oils?"
"Yes. It is always advisable to not mix motor oil brands, however, different viscosity grades of the same brand motor oil are compatible. Be aware that mixing viscosity grades will turn out a product that is different in viscosity than either what was originally in the engine or what was added."
From Shell .ca:
"If you mix viscosity grades such as a 5W30 low-viscosity oil and a 10W40 higher-viscosity oil, it is reasonable to expect that the resulting product will have viscosity characteristics which are thicker than the 5W30, but thinner than the 10W40. This change does not reflect incompatibility - it's simply a re-balancing of the viscosity characteristics. In all other ways, the product should work as expected. But there's absolutely no danger about incompatibility resulting from mixing engine oils," Miller says. "We've tested all of our grades and brands, and we haven't observed any problems."
From Mobil1 .com:
"For our customers to choose a viscosity grade, we recommend they follow the engine manufacturer's recommendations as indicated in their owner's manual. There is no need to mix two Mobil 1 viscosity grades when one will do; however, we see no problem mixing different SAE grades of Mobil 1 Tri-Synthetic series motor oils."
Expand
  • Site Developer
Cheers
Expand
Basically no concerns.
